DA0U81MB6C0 Schematic
  • bhachi
    GALIO Rev A M11 ( HP Pro Tower 280 G9 PCI Desktop PC ) Schematic Needed Or if anyone can tell me the IC details attached
    by bhachi
    Hello There,
    As subject line suggests, can anyone provide the schematic for the same ?
    or can anyone through some lite on the IC/MOSFET/BUCK number ( pictures attached )...
    07-31-2025, 07:23 AM
  • diamon
    Dell Latitude 5520 completely dead
    by diamon
    I have bought a not complete and defective Dell Latitude 5520 for parts (needed the networkconnector (RJ45) to repair a other board).
    Have repaired the other board (Dell Latitude 5540) and I wanted to know if I could find out what is wrong with the 5520 board (SouthPeak15 TGL MB 8L 19819-1) and perhaps repair this one also.
    After connecting the USB-C charger (both USB-C ports on the laptop, does not have an other option) and pressing the power button, nothing happens (no lights or fans, no capslock).
    Have checked with a thermal camera, and there are a couple of things...
    03-05-2025, 02:23 PM
  • Benass
    Marantz NR1601 No Sound, Schematics attached.
    by Benass
    Certainly! Here's a revised version of your text:
    I own a Marantz NR1601 receiver, but unfortunately, I'm experiencing an issue with no sound coming from any of the outputs. I'm seeking assistance to identify the most likely cause of the problem.
    The unit powers on without any issues and seems to be functioning properly. I've noticed that the relay clicks after about 10 seconds, indicating that it's going through its startup sequence. There are no visible signs of damage, and I don't detect any burnt smells.
    While the schematics provided...
    03-11-2024, 03:00 PM
  • vinayck
    ASUS UX481FLY Turns on sometimes
    by vinayck
    Might have some liquid damage (from > 1 year ago, was completely fine until a month ago) - unable to notice anything wrong easily on the motherboard (Core i7, GPU MX250, UX481FLY). I have cleaned parts of the motherboard with some oxidation with solder and flux - did not help.
    Laptop does turn on sometimes and is fully functional. However, while it is fully functional - (1) If rebooted, most of the times it enters a restart loop with blank screen (2) Sometimes, it crashes by itself and enters restart loop - with no relation to CPU/GPU load, heat, etc.
    I found that If I remove the...
    07-06-2025, 12:31 AM
  • Calidebear
    Dell 3537 laptop doesn't boot without embedded display.
    by Calidebear
    I have this laptop for a long time, still it does it's job, like browsing, word , excel. Two years back laptop Hinge base broken but now it's damaging other parts of laptop so I tried to totally remove the embedded display cable from laptop and tried to boot only with external display monitor, but it doesn't boot and gives single beeps. BIOS checking the embedded display to be connected.
    So checked the schematics to bypass this issue.
    Found something but I don't know how to read this schematics.
    Dell 3537 mobo 9982p rev 3
    Schematics attached,...
    03-29-2025, 11:37 AM
