Toshiba C70-C-1G7 AR10SU/CU MB R2.1 - SCHEMATIC
  • benzema1999
    • Mar 2017
    • 5
    • Turkey
    I need schematic for the same model please my friends
  • kalisko
    • May 2016
    • 45
    • Serbia
    Re: Toshiba C70-C-1G7 AR10SU/CU MB R2.1
    Help,
    Need a schematic diagram for Toshiba c70-c
    motherboard: AR10sucu r2.1
    The lcd panel is green, (17.3)
    Tested panel 15.6 is OK
    He tried the other 17.3 images of green
    Tried another flet cable, again the same
    Please help!
    thank you
    • kalisko
      • May 2016
      • 45
      • Serbia
      Toshiba C70-C
      AR10SU/CU MB R2.1
      Here's an example
      Did anyone solve this?
      of the scheme only AR10CU boardview
      Please help me if someone has solved this !!!
      • kalisko
        • May 2016
        • 45
        • Serbia
        Here's the AR10CU boardview
        It can be opened with tsict boardview
        If somebody needs me, I'll send it BoardViewer
        • kalisko
          • May 2016
          • 45
          • Serbia
          Re: Toshiba C70 - C - 1G 7 MB AR10SU/CU R2.1
          Originally posted by kalisko
          Toshiba C70-C
          AR10SU/CU MB R2.1
          Here's an example
          EDIT:
          pictures that are good on the screen 15.6
          and the paintings that are wrong are at 17.3, on his gazelle
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Toshiba C70-C
            AR10SU/CU MB R2.1
            Here's an example
            To me, it seems LVDS cable broken.
            • kalisko
              • May 2016
              • 45
              • Serbia
              Do you think that LVDS is a wire (wire) interrupted?
              on the motherboard or lcd flet cable?
              • kalisko
                • May 2016
                • 45
                • Serbia
                Changed rtd2136n (U4502) and still the same ...
                Has anyone ever solved this?
                Looks like it's not ... who's settling this will get the Nobel Prize
                if someone knows I can pay the solution ....
                I'd like to know what's at stake.
                • ivcha
                  • Jun 2013
                  • 4
                  • Serbia
                  I have the same issue here with green image on 17.3 screen. Have anyone found the solution ?
                  • ivcha
                    • Jun 2013
                    • 4
                    • Serbia
                    Kalisko have you tried 17.3 1366x768 screen ?
                    I have 14.1 screens in both 1366x768 and 1600x900 (From Lenovo T430). On 1366x768 screen image is good but when I connect 14.1 1600x900 I got issue with gray lines appearing randomly on the screen (I guess different symptom due to screen differences . I guess the issue is with LVDS data data channel since HD+ screen use dual channel LVDS.
                    It will be much easier if anyone can provide the schematic.
                    • kalisko
                      • May 2016
                      • 45
                      • Serbia
                      I have a special solution for you ...
                      • ismailakyoltr
                        • Mar 2015
                        • 100
                        • TURKEY
                        Thank you.
