hi, i need the schematic for this laptop model, the touchscreen not working any more. So the S.O is W10 and i has update the drivers and BIOS and can't make to work the touchscreen. When i turn on the computer and i enter to BIOS for run a diagnostic, the touchscreen not work. I think what i have a problem in the motherboard so i need the schematic for this model.thank u every body
HELP!! I need schematic for DELL 13-7359 P57002g
Re: HELP!! I need schematic for DELL 13-7359 P57002g
There is a touch board card inside the screen. Normally that card goes bad if the device is detected in the device manager but with a yellow exclamation mark. However, the card is hard to get unless you have same screen with some other problem. I assume you have already tried serial io driver from manufacturer's site. -
hi mcplslg123, when i see into de device manager there is not a yellow exclamation mark but the device is there, i mean is like a ghost, the device is detected but not work, like a usb when u conect it to a computer and sound "turu"but don't show the usb, maybe the card o the wire is damage, for these reason i need the schematic to check the conections, thank u for you supportComment
If the device is detected without exclamation mark in yellow, then most likley its not hardware issue. try a clean install of windows 10 64 bit and then install serial IO driver from manufacturer's website. Before installing Serial IO driver, do install chipset drivers first.Comment
Hello, as feedback on the touch screen, I have installed w10, I have installed the chipset drivers, then the I / O controller and the touch screen, all this in order but the problem continues, the touch does not respond in W10 and in BIOS, any other suggestions? thanks for your helpComment
DELL Vostro 3450 / Dell Inspiron 14R N4010 DAV02AMB8F1 Schematic & Board View...
Channel: Schematics and Boardviews
by onadjaHello everyone,
I'm looking for the schematic of the motherboard of the Dell laptop XPS 13 Plus 9320 - Compal LA-L071P.
Thank you !...-
10-22-2025, 08:26 PM -
by sourceaxeHi everyone,
Does anyone happen to have the schematic (and if available also: the board view) for the Dell Precision 3650 Tower motherboard please?
Manufacturer: Dell
Model: Precision 3650 Tower
Motherboard markings:- IPRKL-RDT REV: A00
- D33D66
- CN-0NDYHG-PE100-1AM-05SY-A01
- P&Q 2134 CM-4 94V-0 E162264
by lezsimplyHi. Does anybody have schematic for this dell laptop motherboard, LA-G892P Rev. 1.0? I see some post regarding LA-G891P but there's a lot of components missing and there is another winbond chip labeled UT2 close to UT6. Thanks
10-10-2025, 04:21 AM -
Good day everyone.
Got a dell latitude 5285 with motherboard version LA-D89 in the shop today which won't power on. So I opened her up, disconnected the battery and hooked up a charger to see if anything stands out on the board.
I was instantly greeted with the evil glow of a burnt component. Turns out that what looks like a mosfet with silkscreen marking U7 next to it has burnt out. Been looking for a schematic and boardview to check which component it is but have not been able to find one.
Anyone on here have the files laying around?-
08-29-2025, 03:00 PM -
- Loading...
