XPS 13 9365 LA-D781P - Schematic/BoardView need
  • outsider
    • Apr 2014
    • 104
    • localhost
    I need schematic and BoardView to:
    XPS 13 9365
    BAZ80 LA-D781P REV:1.0 (A00) 2016-09-13
    Thank you!
  • mon2
    • Dec 2019
    • 14667
    Re: XPS 13 9365 LA-D781P - Schematic/BoardView need
    Another thread has the same request. PDF is encrypted from a paid service so attached are snippets of the schematic. Do not have boardview.
    • traveler_ua
      • Jan 2021
      • 17
      • Netherlands
      Thank you
      • dvbsmc
        • 17
        XPS 13 9365
        Thank you!
        Compal LA-D781P r1.0
        • ant34i
          • Aug 2014
          • 10
          • Mexico
          Thanks my friend. This zip have PDF file.
          • Shakil3720
            • Nov 2018
            • 5
            • Bangladesh
            • brother john
              • Jul 2022
              • 13
              • burmese
              thanks
              • EnergeticHalfling
                • Nov 2023
                Originally posted by Shakil3720
                New to the CAD file. What can I use to view this?
                • EnergeticHalfling
                  • Nov 2023
                  Figured it out!
                  • honis7
                    • Nov 2013
                    Figured it out!
                    Hi I am trying to open .cad boardviews, how did you do it?
                    • Lisa Su
                      Lisa Su commented
                      Editing a comment
                      You can open it with BoardViewer 2.0.1.9.
                      First link on Google.
                  • siroos_tz
                    • Feb 2014
                    • 121
                    • the UK
                    • jesi
                      • Jul 2013
                      • 78
                      thanks
                      • kkostin079
                        • May 2024
                        • 3
                        Thank you very much!
                        • Noreddin
                          • Jan 2020
                          • 73
                          • mostaganem
                          thanks
                          • PacoGT
                            HP ENVY x360 gidget 8L 203038-1, boardview and schematic need
                            by PacoGT
                            hello firends
                            i search the schematic or boardview
                            I have this motherboard, but I can't find the schematic or the boardview.
                            The problem is that on the chip marked where 3V should be, there are 5 volts, which indicates that the two are connected.
                            So the computer doesn't turn on, and the 3V disappears after a few seconds.
                            The original problem was that when I turned off the computer, the fan stayed on and saw that it was bad since it was directly in the 5V area.
                            The new problem arose after removing the bad chip.
                            3V and 5V remained together,...
                            08-19-2025, 08:25 PM
                          • hosain0489
                            Request for Schematic and Boardview for HP Omen 16-xf0006AX (AMD Ryzen 7 7840H Version)
                            by hosain0489
                            I’m looking for the schematic and boardview files specifically for the AMD version of the HP Omen 16 laptop, model xf0006AX, equipped with the Ryzen 7 7840H CPU.
                            Most of the files I’ve found are for Intel CPU versions, and I need the exact files for this AMD Ryzen 7 7840H model to assist with repair and troubleshooting.
                            If anyone has access to these files or can kindly share the boardview and schematic for this particular AMD version, I would really appreciate your support.
                            Thank you very much in advance!
                            07-15-2025, 11:20 AM
                          • re-atari
                            Gigabyte GA-H110-D3A schematic/boardview needed
                            by re-atari
                            Hello all,
                            Does anybody have a schematic and/or boardview of the Gigabyte GA-H110-D3A mainboard available? It would really help me out big time...
                            This board was donated to me in a known non-working state. In its previous life it was used as a mining board, so I suspected bad caps and a relatively easy fix. My intention is to use the fixed board as a testbed for a Truenas or Unraid build. The previous owner told me that the mainboard started to act 'weirdly' after replacing the originally installed Celeron for an i5-6400, varying from starting up irregularly to not at...
                            02-24-2025, 06:45 PM
                          • jonyhdtv
                            HP ProBook X360 11 G3 ee (winbook) schematic and boardview thanks
                            by jonyhdtv
                            Looking for schematic and boardview
                            Model: HP ProBook X360 11 G3 EE
                            Serial: SCG9114JG7
                            Motherboard: L43774-601
                            defect: touchscreen doesn't work (touch works on another computer)
                            thanks to all​
                            01-29-2025, 08:16 AM
                          • jonyhdtv
                            HP ProBook X360 11 G5 ee schematic and boardview thanks
                            by jonyhdtv
                            HP ProBook X360 11 G5 ee (winbook) schematic and boardview thanks
                            Model: HP ProBook X360 11 G5 EE
                            Serial: SCG0164QLH
                            Motherboard: L83950-601
                            defect: no POWER
                            thanks to all​
                            01-29-2025, 08:11 AM
