EC300 Marine Control Board schematic
  • mpikou
    • Jun 2013
    • 58
    • Greece
    I am looking for EC300 Marine Control Board schematic.
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • Joseph Abraham
    skyworth air conditioner control board schematic diagram needs
    by Joseph Abraham
    hi every body 😗
    i have two air conditioners skyworth brand and i need schematic diagram of control board, acutely they did not work any more ( compressor startup failure ) and display appears ( H1 ) error code, any help plz to diagnostic this problem and how to fix it?
    i will be very appreciate thankyou 🤗
    07-08-2025, 09:07 AM
  • Yanleb
    LG 60PK550 Logic Control Board EBR63450301
    by Yanleb
    Hi all, I just want to share the repair of my 60PK550-UA TV set.
    The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
    But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
    All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
    C57: 3.30V
    C61:...
    07-20-2023, 12:38 AM
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
    Linear Garage Door Opener Control board took a crap install a new control board back normal
    I have been having issues with this garage door opener for a while first the range of the remote was a lot less and sometimes it would start to go down and stop for no reason that I could find and would every once in awhile to start with then it started going more frequently until last Saturday when I opened the garage door it refused to close so I cranked up force all the way maximum limit this did not work also the sensor on one side that has a green and red lights that are supposed to be on when the door is open and there are no obstacles in the way on the original board the only light that...
    02-08-2025, 06:52 AM
