fujitsu ah531
  • alfredodinolfo
    • 128
    • N/A
    fujitsu ah531
    hi, i need boardview for DAOFH5MB6F0 rev F.
    Thank you
    • 21917
    Re: fujitsu ah531
    https://www.badcaps.net/forum/showthread.php?t=55020
    • tofuSCHNITZEL
      Fujitsu Lifebook E547 vPro
      by tofuSCHNITZEL
      I have a Fujitsu Lifebook E547 vPro that does not boot anymore after Windows Update tried to install a new Bios version. Screen stays black no post - only the numblock light blinks.
      What I've tried:
      I have used my CH341A to read the bios chip (25Q128FVSQ) (Dump attached) - I think the dump is "good" because I could find the Serial number in the data and also the Winkeyfinder found a windows key.
      for the lack of any other Idea I took the bios from this post (https://www.badcaps.net/forum/troubl.../troubleshooti...
      10-15-2025, 04:26 PM
    • angel35
      Fujitsu server board D3445-K12 schematic or/and boardview request
      by angel35
      I would like to request an very rare Fujitsu server D3445-K12 or K11 motherboard schematic or boardview, It is from Kuka Robot control KRC4
      (Skylake 6th gen, H110)
      It has 27V power circuit SMD DC-DC ->12->5->3.3V
      Maybe the simple D3445-S is same like file but missing not mounted 27V circuit, but some parts same like.
      thanks...
      07-26-2024, 12:19 PM
    • Duranitron
      Fujitsu Lifebook AH53/X Need Schematics or boardview
      by Duranitron
      Fujitsu Lifebook AH53/X FMVA53XBKS
      Specs: Intel i7 processor, 8Gb ddr4 memory module, 250Gb SSD,
      date stamp is 2016
      Motherboard model: ADZAM-6050A2761701-MB-A01
      Symptoms: Sometimes the unit will turn on made it to the windows login screen then turns off, most of the time the Unit can be turn on but only the power on is lit and will eventually turn of in less than 30 seconds, CPU fan spins, no beep code and no display.🤕🤕🤕
      Basics: replaced known good 19v adapter, replaced known good ddr4 memory module, test the always on voltage 5v, 3.3v all...
      04-29-2025, 10:16 PM
    • qba82
      Schematics or boardview for Fujitsu H760 CP714673-01
      by qba82
      Hi, anyone have schematics or boardview for Fujitsu H760, motherboard no. CP714673-01
      thanks
      11-12-2023, 01:08 AM
    • TacticalFahrrad
      [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
      by TacticalFahrrad
      I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
      BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
      I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
      06-30-2025, 04:09 AM
