HP Envy-15-as010ca
  • xr4ti
    • Dec 2014
    • 7
    HP Envy-15-as010ca
    Hello Everyone,
    I'm looking for the schematic for HP nvy-15-as010ca Motherboard is:
    Vanilla 6050A2821201-MB-A01
    OR SIMILAR SCHEMATIC that uses PWM Driver :SiC631
    don't have "enable" signal for video and don't know where is it coming from!
    Please help!!
    Thank you in advance.
  • xr4ti
    • Dec 2014
    • 7
    Re: HP Envy-15-as010ca
    I downloaded this schematic: hp envy VANILLA 1-6050A2857201-MB-A01.rar
    but it is corrupted, will not unzip/unrar.
      • 20745
      Where did you download it, theres a file with the same name in the bios requests section - post #4 https://www.badcaps.net/forum/showthread.php?t=79784 .Its a bios. Update winrar or use 7-zip.
      • xr4ti
        • Dec 2014
        • 7
        Thank You SMD Flea,
        Indeed, I did download this file (twice) from post #4, but it is corrupted anyway, I used 7-zip (latest ver.), and WinRAR, and windows itself.
        Can not be opened.
        • BC_TechForum_drb
          Missing enable on +5v sec pwr rail AMD Firepro D500-B/Mac Pro late 2013
          by BC_TechForum_drb
          Sub: Missing enable on +5v sec pwr rail AMD Firepro D500-B/Mac Pro late 2013
          Ref: 1/ MacPro6,1 Late 2013/A1481 MD878LL/A (3.5 GHz 6 Core Xeon E5-1650v2)
          Gfx-B: APN: 661-7548 PPN: 820-3533-A AMD FirePro D500-B 3GB Vmem
          2/ Figure 1 Gfx-D500-B Front Facing
          3/ Figure 2 +5v supply (zoom-in)
          Intro:
          While troubleshooting a Mac Pro(6,1) referenced above I discovered the +5v secondary supply did not stand up on the D500-B graphics card as a result of a missing enable signal. The +3.3v secondary rail was the only rail that did standup. I tried to perform...
          12-07-2023, 09:55 PM
        • Talonts
          Dell Latitude 7290 enable touchscreen entry in BIOS?
          by Talonts
          For those that have worked through the 7290 BIOS in the past, do you happen to know if there is a switch in it to enable a touchscreen entry in the BIOS setup?
          The 7290, 7390, and 7490 all use the same BIOS, and the 7390 has an FHD touchscreen as one of its' options. It turns out it can be installed in a 7290 BUT since the BIOS doesn't have the entry to turn it on, it just becomes an FHD upgrade to the 7290.
          I was hoping if any of you that had worked on the BIOS in the past would know if either the touchscreen settings could be turned on in the 7290, or the BIOS could...
          06-24-2025, 11:27 PM
        • tccyo22
          Xbox One Original missing 12v enable signal
          by tccyo22
          Hi there, I have an Xbox One original in which I have all the 1.8v, 3.3v and 5.0v standby power rails present, however my 12v rail is not turning on and the enable signal PSU_V12P0_EN from the SMC to turn the power supply on is missing. There is high resistance on this line so it's not shorted directly to ground which leaves me with not many options.
          Was looking at a schematic and see the enable is created by the SMC. I have 3.3v on SMC_RST_N_IN but I'm a little stuck on where to look next. Is it likely that the SMC has gone bad or am I missing something else (it's my first time with...
          08-14-2023, 06:06 AM
        • iulik17d
          HP ProDesk 400 G5 SFF BIOS 4G decode & REBAR enable
          by iulik17d
          Hello everyone!
          I've paired an Intel Arc A380 with this PC but the performance is not so good because the bios don't have 4G decode and Resizable BAR enabled.
          With an CH341a I extracted the .bin file from the 25Q128 SPI memory. Can someone work some magic on that .bin file to enable or add the 4G decode and REBAR to it?
          The model number is: 2ZX70AV
          Thank you!...
          01-10-2025, 01:49 PM
        • simsuhow
          NEC VKT16B-5 use Lenovo NM-B891 board, please help to enable camera
          by simsuhow
          Hi, I bought second from someone this NEC VKT16B-5, and found that it actually have camera but was disabled, not detect at all in device manager, can't find any setting in BIOS.
          And it use LENOVO NM-B891 Rev.2 board, so, I tried to flash a BIOS downlaoded from here
          https://www.badcaps.net/forum/troubl...-request/page2
          reply #21, so, I confirm the camera works fine.
          Is anybody can help to modify my NEC backup...
          12-11-2024, 03:40 AM
