Try This
Required t480 nm-b501 schematic
by hemant_2222Hello Friends,
Greetings!
I have taken this active subwoofer from Wharfedale for restoration. This is already in a bad shape as far as the connections goes. It has already been worked by local technicians. The most important part that I am looking forward is the schematic diagram, as there is jumper placed and a track has been cut, as if to bypass the actual connection. I am not sure if this is by design or someone has tried something to achieve.
Another thing is the TDA7294 was badly treated with its legs cut and it had a crack too, so I have replaced it...-
by HasoobiHi Master's Help Required HP Pavilion DV2 Laptop
PCB : P/N:HPMH-41-AB3700-D00G
PWA : P/N:HPMH-40GAB3700-D
REV : D-
Channel: Schematic Requests ONLY!
06-04-2025, 08:22 AM -
by Mx7NineDoes anyone have a schematic/boardview for:
Dell 5310 2-in-1
Bandon_MLK_TBT MB 10L
19707-1
GDYT7$CA
It would be much appreciated.
Thanks.-
by PEDROPERICOHi, I have a LENOVO THINKBOOK 14S YOGA GEN2 with motherboard LA-M062P that does not turn and not charge and I need the schematic in case someone can share it, thanks, greetings.
by timematcherDear friends,
I am in need of the schematic diagram for DAX32DMAD0 HP Spectre X360 15-BL112DX (8th generation)
Thanks...-
04-18-2024, 06:08 AM -
- Loading...
