Try This
Required t480 nm-b501 schematic
here
Attached Filesif you find these attachements useful please consider making a small donation to the site
by hemant_2222Hello Friends,
Greetings!
I have taken this active subwoofer from Wharfedale for restoration. This is already in a bad shape as far as the connections goes. It has already been worked by local technicians. The most important part that I am looking forward is the schematic diagram, as there is jumper placed and a track has been cut, as if to bypass the actual connection. I am not sure if this is by design or someone has tried something to achieve.
Another thing is the TDA7294 was badly treated with its legs cut and it had a crack too, so I have replaced it...-
by wingsI sent my motherboard for a warranty replacement, but the request was rejected due to burn damage. The issue occurred after I connected an HDMI-to-VGA converter for an old monitor. The converter had its own power adapter, and I believe this external power supply damaged the HDMI chip on the motherboard.
After that, I took the board to a local technician ("Technician A"), who said he couldn’t repair it. Finally, I brought it to a more experienced technician ("Technician B"), who discovered that the HDMI chip was missing from the board.
Now, I need...-
10-29-2025, 10:20 PM -
by bhamraHi,
Please provide the boardview and schematic for hp pavilion 14-bf
motherboard : DCM40 LA-F031P Rev : 1.0
Thanks-
10-07-2025, 05:48 PM -
by HasoobiHi Master's Help Required HP Pavilion DV2 Laptop
PCB : P/N:HPMH-41-AB3700-D00G
PWA : P/N:HPMH-40GAB3700-D
REV : D-
06-04-2025, 08:22 AM -
by Mx7NineDoes anyone have a schematic/boardview for:
Dell 5310 2-in-1
Bandon_MLK_TBT MB 10L
19707-1
GDYT7$CA
It would be much appreciated.
Thanks.-
- Loading...
