Required t480 nm-b501 schematic
  • SAND123
    • Nov 2019
    • 7
    • india
    Required t480 schematic
    • 21869
    Re: Required t480 schematic
    What is the motherboard part number ?
    • LenBios
      • 122
      • Ker
      LENOVO THINKPAD T480 shematics
      • NiroPall
        • Dec 2018
        • 119
        • Sri Lanka
        Re: LENOVO THINKPAD T480 shematics
        Thank you dear
        • aideheqq
          • Jan 2021
          • singapore
          Originally posted by smdflea
          what is the motherboard part number ?
          nm-b501
          • rumensat
            • Apr 2010
            • 25
            Originally posted by aideheqq
            nm-b501
            thank you very much
            • ku6u
              • Jul 2021
              • moldova
              Thank YOU!!!
              • JointDexter
                • Jun 2021
                Hey, I'm trying to figure out if this is the same schematic for the board in my T480. The motherboard is labeled NM-B47 and I know the schematic above is for NM-B501. Not sure if they are similar enough or not.
                All I'm trying to do is get the correct part number for the HDMI port because this one is mangled up and needs to be replaced.
                • alas3376
                  • Nov 2011
                  • 382
                  • BENIN
                  thank you
                  • Siddig
                    • Jun 2017
                    • 264
                    • Sudan
                    Thank you dear
                    • ghass
                      • Apr 2014
                      • 45
                      • lebanon
                      thanks
                      • Alt_Star
                        • Nov 2021
                        • India
                        pls give boaedview also
                        • echow2001
                          • 44
                          Re: Required t480 nm-b501 schematic
                          jtag pinout guide here from studying schematic and probing around board. the jtag is covered by silkscreen and under the WWAN card on front (side with cpu) of board jtag reset JTAG_RST pull up/pull down located near EC check silkscreen to see where. Hope this helps
                          • vicmark63
                            • May 2023
                            • 10
                            Thanks alot!
                            • Darkalatreon
                              • Feb 2022
                              • México
                              thanks
                              • Noreddin
                                • Jan 2020
                                • 73
                                • mostaganem
                                Thank you
                                • konare
                                  • Aug 2022
                                  • 43
                                  • Mali
                                  Hi
                                  I need the lenovo t480 nm-b501 boardview​
                                  thank you
                                  • lord
                                    • May 2011
                                    • 319
                                    • Croatia
                                    Can anybody help?
                                    I have this one for repair, does not charge the battery, does not bring up 20V from the charger. So i input 20v to VSYS from dc power source, now it turns on for a 15 seconds and turns off. Current consumption is 600-700mA. As i can see all power supplies are on expect GFX integrated. Also tried to inject 20V to all the 20V rails at the same time: VSYS, VINT20_IN and USBC_VBUS20 but nothing changes.
                                    Question is, should it turn on with only VSYS supplied?
                                  • chaz brandon
                                    • Jun 2020
                                    • 28
                                    • Uganda
                                    Any one please help with Lenovo T480 B501 Boardview
                                    • chaz brandon
                                      • Jun 2020
                                      • 28
                                      • Uganda
                                      Originally posted by konare
                                      Hi
                                      thank you
                                      Did you get this lenovo t480 boardview
