Asus UX410U or UX310U
  • bakre
    • Dec 2014
    • 105
    • Zwolle
    Hello gays
    Do any one have this board view or schematics for this Asus UX410U
    or UX310 they have the same circuit i think.
  • alexvan59
    • Mar 2021
    • 23
    • France
    ASUS ux410u - Boardview and/or schematic
    I was not able to find anything for ASUS UX410U. Does anybody have the schematic and/or the boardview?
    I believe the board is similar to ASUS UX310 but not sure (asus said that just the screen is different).
    Thanks for any help
    • mon2
      • 14244
      Re: ASUS ux410u - Boardview and/or schematic
      hi. is your board layout like the attached? This is the boardview of the ux410.
      • Spider1211
        • Oct 2019
        • 532
        • Mauritius
        Hi mon2, is it possible to have the boardview file please?
        • alexvan59
          • Mar 2021
          • 23
          • France
          It really looks like this one. Not sure at this size but it seems to match perfectly.
          May you share the files?
          Alex
            • 20977
            Re: Asus UX410U or UX310U
            Merged your thread with an older one requesting the same .
              • 20977
              Asus UX310UV UX310UA UX310UQ Rev 2.0 Boardview
              • alexvan59
                • Mar 2021
                • 23
                • France
                Hi SMFFlea,
                Thank you very much.
                The boardview is correct for my board, it will really help.
                The repair guide is for UX410UQ. The pictures of the mainboard are different from mine.
                Thank you again!
                  • 20977
                  You`re welcome. I removed the UX410UQ repair guide.
                  • alexvan59
                    • Mar 2021
                    • 23
                    • France
                    Ok, after looking more closely: my board is similar to the ASUS UX310UV : the general layout is the same (position of CPU, GPU, RAM, jack) but some components seems slightly different. It's better than nothing because some areas are really similar/same but if we can get the real one, that would be even better
                    Mon2, if you can share your file, it would be great to compare.
                    • Spider1211
                      • Oct 2019
                      • 532
                      • Mauritius
                      @SMDFlea, would you mind sharing the repair guide also please?
                        • 20977
                        i posted it in a new thread - https://www.badcaps.net/forum/showthread.php?t=94392
                        • Spider1211
                          • Oct 2019
                          • 532
                          • Mauritius
                          Thank you!
                          • alexvan59
                            • Mar 2021
                            • 23
                            • France
                            Ok, did more check. I was wrong. The file UX310UV is really the right one for my UX410UV. I was not enough experimented but after some time, I've got used to the software and I'm now sure, the file is correct .
                            • selekop
                              • Aug 2017
                              • 21
                              • türkiye
                              thank you broo
                              • AL._.EX
                                • Dec 2022
                                • 873
                                • Belarus
                                Repair guide
                                • zaffar
                                  • Jul 2020
                                  • 7
                                  Looking for an Asus UX310 UQR schematic, boardview or anything you have. Trying to fix the issue with random shorts on mosfets near CPU.
                                  • isitsupport1
                                    • Jul 2023
                                    • sri lanka
                                    Thanks Dear.
                                    • garouppa
                                      • Oct 2023
                                      • Tunisia
                                      Hi
                                      Thank you for this post, unfortunately I tried to open the fz with fritzing 1.0.1 (the only version that I could get hold of) and couldn't open it (after unzipping of course), I get "parse error, encountered incorrectly encoded content".
                                      Does it happen you to have another version , or know what fritzing I could use please ?
                                      With all my thanks
                                      Gar
                                        • 20977
                                        Originally posted by garouppa
                                        Hi
                                        With all my thanks
                                        Gar
                                        This is quite a common mistake,you do not need fritzing. You can use BoardViewer from boardviewer.net or openboardview if the fz license key is added. https://www.badcaps.net/forum/showpo...16&postcount=7
                                        • razor_amd
                                          by razor_amd
                                          12-15-2020, 07:07 PM
                                        • DynaxSC
                                          Activation of Management Engine after exchange Z590 chipset - ASUS PRIME Z590M-PLUS
                                          by DynaxSC
                                          Hi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
                                          For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent...
                                          06-10-2023, 11:30 AM
                                        • alexvan59
                                          ASUS ux410u - No power no charge
                                          by alexvan59
                                          I have an ASUS ux410u that is no boot no power. I'm trying to find out the issue and I'm seeking for help. I'm not a specialist, I have a background in electronics from engineering schools but nothing more.
                                          The good news is that I have another ux410u that is working perfectly, so, I could compare if needed.
                                          I've disassembled it and isolated the mainboard of the defective one and made some checks:
                                          * the power port is ok, I get 19.4v on the board
                                          * After the two first mosfets, I still have 19.4v
                                          * Without doing any voltage injection...
                                          03-24-2021, 03:38 PM
                                        • sikocan
                                          ASUS UX580G Laptop
                                          by sikocan
                                          UX580G Laptop
                                          Motherboard: UX550GD REV 2.2
                                          ITE IT8225VG Chip
                                          Asus website: https://www.asus.com/au/supportonly/...desk_download/
                                          Windows BIOS: https://dlcdnets.asus.com/pub/ASUS/n..._Installer.exe
                                          Manual BIOS: https://dlcdnets.asus.com/pub/ASUS/n...50GDXAS312.zip
                                          10-27-2022, 10:41 PM
                                        • lrouw84
                                          Asus vivobook s510ua bios changed to x510un
                                          by lrouw84
                                          Hi there,
                                          I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
                                          I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
                                          01-28-2023, 01:31 PM
