MSI MS-16gh1 need schematic - distorted sound
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3577
    • slovakia
    MSI Gaming laptop MS-16gh1 need schematic - distorted sound
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3577
    • slovakia
    Re: MSI MS-16gh1 need schematic - distorted sound
    come on guys. no scheamtic or boardview?
      • 20649
      Schematic
      • Tbh97
        • Sep 2021
        • 5
        • Spain
        Originally posted by SMDFlea
        Schematic
        Hey , I can't find MSI ms-16k61 schematics I will be tankful if you can help me with it.
          • 20649
          Originally posted by Tbh97
          Hey , I can’t find MSI ms-16k61 schematics I will be tankful if you can help me with it.
          Different one to the thread topic, start a new thread and request it.
          • Tbh97
            • Sep 2021
            • 5
            • Spain
            Okay I will hopefully someone can help! Thank you!
            • Tbh97
              • Sep 2021
              • 5
              • Spain
              Here it is I posted my first Thread:
              https://www.badcaps.net/forum/showth...73#post1068573
              • LEECH666
                Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                by LEECH666
                Good day ladies and gentleman!
                I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                01-19-2024, 05:46 PM
              • maleksa
                Yamaha MOX8 boot freeze and distorted sound
                by maleksa
                My Yamaha MOX8 synthesizer recently developed two issues.
                Firstly, after booting up, it operates as normal. However, after about 5 minutes, the sound starts to get distorted (broken up screeching sound) almost like putting it through a guitar distortion pedal. After a while, the distorted sounds will go away for a while and comes back. At times, the synthesizer will also freeze I need to power off and on again.
                Secondly, when powering off and on again, there will be times where the synthesizer will freeze during the boot sequence (freezes at the MOX8 Opening Screen),...
                11-07-2024, 03:28 AM
              • ChaosLegionnaire
                by ChaosLegionnaire
                09-13-2022, 09:02 AM
              • televizora
                HP 8470p - distorted sound and noise when playing audio
                by televizora
                Hello.
                I have an issue with HP 8470p - rather strange one.
                I have a noise and sound distortions on both internal speakers and external speakers, when I plug such into the 3.5mm audio jack.
                Seems like the noise is present especially when I play audio, where there are parts/sections where the volume of the actual recorded sound is low.
                Interestingly, when I play the windows sound test, everything seems to be almost okay. The sound/distortions are similar to when you have interference from some other piece of equipment nearby or when you have an audio receiver with bad amplifier...
                12-31-2021, 10:25 AM
              • Hillybilly
                philips HTS3530/05 sound system Schematic
                by Hillybilly
                Hi I've been trying to test for a fault on a pcb code 40-S351OA-PWB1G and ha ving tested a certain component with multimeter and atlas dca55 which came up with faulty component also the multimeter set to a diode mode couldn't get a reading.on board i'ts zd501,could anyone tell me if this component would make the pcb drop 42v which supplies to amp side of philips HTS3530/05 sound system please.A schematic with codes for parts would be much appreciated.Thanks
                07-24-2023, 08:13 AM
