Hello! I am asking for a schematic of the ideapad 320 14ikb mainboard, specifically the dg421 dg521 dg722 nm b242 version. I have searched online, but am unable to see one for the kaby lake version. I have no need for the BIOS. Thank you!
ideapad 320 14/15/17 IKB DG421 DG521 DG721 NM B242 rev. 1.0 schematic
Re: ideapad 320 14/15/17 IKB DG421 DG521 DG721 NM B242 rev. 1.0 schematic
Schematic -
ideapad 320 IKB NM B242 board view
Good day! I am looking for the board view of DG421 DG521 DG721 NM-B242 (ideapad 320) Thanks! The closest things I could find are
http://xn----8sbafotoqlagnhme.xn--p1...oardview.16883
https://************/threads/lenovo-80xh-nm-b241.29823/
Thank you!Comment
Re: ideapad 320 IKB NM B242 board view
I finally managed to find boardview, maybe it will be useful for someoneGood day! I am looking for the board view of DG421 DG521 DG721 NM-B242 (ideapad 320) Thanks! The closest things I could find are
Thank you!Comment
I have a problem with same board, it starts only if I reset bios(pull out battery and bios battery) but after I shut it down it doesn't start again only if I reset it ...
I can make it to reset every time when I shut down but isn't a nice method ...
anyone had this problem?
thanks!Comment
Start a new thread in the main laptop forum, this is the schematic requests section.I have a problem with same board, it starts only if I reset bios(pull out battery and bios battery) but after I shut it down it doesn't start again only if I reset it ...
thanks!
Main laptop forum https://www.badcaps.net/forum/forumdisplay.php?f=23Comment
Lenovo IdeaPad 320-15IKB DG421 DG521 DG721 Laptop Schematic
NM-B242 NM-B241 Rev 1.0...-
Channel: Schematics and Boardviews
10-08-2024, 01:49 AM -
by AustinCERHello,
I am in search of a schematic or boardview for Lenovo Ideapad Flex 5 14ALC7.
No power and no charging LED with AC Adapter connected. AC Adapter is functioning at 19V, and also tried another Lenovo AC Adapter -- no charging LED still.
There is an active 19V from the USB-C port to the motherboard with AC Adapter connected, so the port is also fine. I am assuming there is a short on one of the power rails, but don't know where to start looking.
Any insight, schematic or boardview would be greatly appreciated.
Model: Lenovo Ideapad Flex 5 14ALC7...-
Hi, looking for a schematic for an IdeaPad 5 15IIL05. I'm just getting into repair, so sorry if I missed anything. I tried searching, but didn't find anything other than bios dumps.
And if anyone has any suggestions, If I press the power button, the button lights up, but no fan spin, no monitor or anything. After schematic I will check the rails, I just don't know where any of them are
Hello all, looking for specific schematic and boardview for this ideapad flex 5. Model name is 81SQ if that matters. Motherboard model is EL4C1/EL451 LA-H081P. Thanks!...
by lint4uHello SIr
Could you pls hared the schematic for ideapad gaming 3
Board Code : HLG30 LA-L916P
BR-
01-27-2025, 11:09 PM -
- Loading...
