Toshiba l505d schematic or boardview plz. Help me
Toshiba l505d schematic please
Tags: None
Re: Toshiba l505d schematic please
does that help you?Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
by outsiderHello
I need schematic and boardview to:
Toshiba Satellite L50D-A series
PCB: Pegatron VGADT VGADTG 10ADTG
Thanks!-
by PacoGThello firends
i search the schematic or boardview
I have this motherboard, but I can't find the schematic or the boardview.
The problem is that on the chip marked where 3V should be, there are 5 volts, which indicates that the two are connected.
So the computer doesn't turn on, and the 3V disappears after a few seconds.
The original problem was that when I turned off the computer, the fan stayed on and saw that it was bad since it was directly in the 5V area.
The new problem arose after removing the bad chip.
3V and 5V remained together,...-
08-19-2025, 08:25 PM -
by hosain0489Hello everyone,
I’m looking for the schematic and boardview files specifically for the AMD version of the HP Omen 16 laptop, model xf0006AX, equipped with the Ryzen 7 7840H CPU.
Most of the files I’ve found are for Intel CPU versions, and I need the exact files for this AMD Ryzen 7 7840H model to assist with repair and troubleshooting.
If anyone has access to these files or can kindly share the boardview and schematic for this particular AMD version, I would really appreciate your support.
Thank you very much in advance!
by re-atariHello all,
Does anybody have a schematic and/or boardview of the Gigabyte GA-H110-D3A mainboard available? It would really help me out big time...
This board was donated to me in a known non-working state. In its previous life it was used as a mining board, so I suspected bad caps and a relatively easy fix. My intention is to use the fixed board as a testbed for a Truenas or Unraid build. The previous owner told me that the mainboard started to act 'weirdly' after replacing the originally installed Celeron for an i5-6400, varying from starting up irregularly to not at...-
by jonyhdtvHP ProBook X360 11 G3 ee (winbook) schematic and boardview thanks
Looking for schematic and boardview
Model: HP ProBook X360 11 G3 EE
Serial: SCG9114JG7
Motherboard: L43774-601
defect: touchscreen doesn't work (touch works on another computer)
thanks to all-
- Loading...
