z5wah la-b162p REV 1.0 schematic please
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Hi i need a correct schematic for this model because the PU401 ic got burned and I font have the exact model .
  • peste
    • Dec 2016
    • 13592
    • ROMANIA
    Re: z5wah la-b162p REV 1.0 schematic please
    try...
    • kalilinux25
      • Mar 2018
      • 2089
      • ZAMBOANGA SIBUGAY
      I tired to change the pu401 ic but after a minute it keeps damaging the ic
      • fyaagoub
        • Dec 2016
        • 269
        • maroc
        • manana2019
          • Apr 2019
          • 32
          • malaysia
          Hai sir,thanks for schematics
          • starsiege72
            • Dec 2020
            • Bulgaria
            Thanks for the schematic!
            • danjeneth
              • Aug 2020
              • 3
              • phil
              up i need it also
              • TinkerTron
                Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                by TinkerTron
                Hey everyone,
                I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                Instead, here's what's been bugging me so far:
                The schematic...
                03-06-2025, 02:03 PM
              • atunguyd
                Acer x163w Monitor PSU schematic
                by atunguyd
                Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
                The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
                03-05-2025, 02:08 PM
              • Thetechdude
                MSI Ventus RTX 4080 16G Broadview schematic needed
                by Thetechdude
                Hi guys, I'm working on a MSI Ventus RTX 4080 16G. The GPU has 12v, 5v, however what I assume is the 1.8v rail has 1.1v and what I assume to be PEX is 0v. As you may have guessed already there is no Vmem and no Vcore.
                I have looked around in related forum posts for a schematic so Much appreciated if anyone can share a Broadview schematic.
                Thanks.
                07-15-2025, 11:15 AM
              • ianpoultonknights
                Zenbook Flip 15 UX562AI schematic
                by ianpoultonknights
                Had one of these come in for repair with a blown battery and a WiFi issue, battery has been replaced with genuine battery (twice) and won't take a charge works fine on AC, WiFi issue gone away. Looking for a schematic so I can trace the charger circuit UM562F is only one I can find, this is the 562AI model.Had a unit come in for repair — 562AI model — with a blown battery and WiFi issue. WiFi fault has cleared, but battery won’t charge despite replacing it twice with genuine parts. Device operates fine on AC power. Suspect charger circuit fault. Only schematic I’ve found so far is for...
                06-26-2025, 02:41 PM
              • Adv10119
                Need help please! schematic for LA-9982P rev 3.0 (A02)
                by Adv10119
                Please help, i need schematic diagram for Dell inspiron 3537 board LA-9982P rev 3.0 (A02). Specific for A02.
                I have a one beep with no display problem. Did reprogrammed the bios but no luck. i tried to troubleshoot using rev 3.0 (A08) version schematic and boardview but there's components/rails in the schematic that is none in my actual board, this is why I'm having problem checking every power rail needed if ok. attached is the photo of my actual board.
                I'm not sure if A02 and A08 is really different schematic version from each other, but I have to try....
                01-31-2024, 01:18 AM
