BV and schematic for 820-3435 please
  • nusilor
    • Jan 2019
    • 23
    • aus
    any one have BV and schematic for 820-3435
  • riki_22
    • Jun 2014
    • 65
    • italia
    Re: BV and schematic for 820-3435 please
    here's to you
    • nusilor
      • Jan 2019
      • 23
      • aus
      thanks
      • nusilor
        • Jan 2019
        • 23
        • aus
        here they are together
        • BoozZzy
          • Sep 2018
          • 8
          • ukraine
          thanks)))
          • acs8369
            • May 2020
            • Thailand
            thank you
            • adsr
              • Feb 2021
              Very kind, thank you.
              • Mechanicalbytes
                • Apr 2020
                • 30
                • jipikiller
                  • Aug 2020
                  • 15
                  • arg
                  Thanksssssssss
                  • tooko
                    • Nov 2014
                    • 38
                    • france
                    Thanks !
                    • DopplerDuck
                      • Nov 2019
                      • India
                      Thank you!
                      • erickj007
                        • Oct 2021
                        • 6
                        • Philippines
                        thanks
                        • Cliffhanger
                          • Jan 2023
                          • France
                          Thanks a million !
                          • Jse Enrique
                            • Feb 2021
                            • 38
                            • cuba
                            thanks bros
                            • TinkerTron
                              Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                              by TinkerTron
                              Hey everyone,
                              I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                              Instead, here's what's been bugging me so far:
                              The schematic...
                              03-06-2025, 02:03 PM
                            • atunguyd
                              Acer x163w Monitor PSU schematic
                              by atunguyd
                              Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
                              The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
                              03-05-2025, 02:08 PM
                            • Thetechdude
                              MSI Ventus RTX 4080 16G Broadview schematic needed
                              by Thetechdude
                              Hi guys, I'm working on a MSI Ventus RTX 4080 16G. The GPU has 12v, 5v, however what I assume is the 1.8v rail has 1.1v and what I assume to be PEX is 0v. As you may have guessed already there is no Vmem and no Vcore.
                              I have looked around in related forum posts for a schematic so Much appreciated if anyone can share a Broadview schematic.
                              Thanks.
                              07-15-2025, 11:15 AM
                            • ianpoultonknights
                              Zenbook Flip 15 UX562AI schematic
                              by ianpoultonknights
                              Had one of these come in for repair with a blown battery and a WiFi issue, battery has been replaced with genuine battery (twice) and won't take a charge works fine on AC, WiFi issue gone away. Looking for a schematic so I can trace the charger circuit UM562F is only one I can find, this is the 562AI model.Had a unit come in for repair — 562AI model — with a blown battery and WiFi issue. WiFi fault has cleared, but battery won’t charge despite replacing it twice with genuine parts. Device operates fine on AC power. Suspect charger circuit fault. Only schematic I’ve found so far is for...
                              06-26-2025, 02:41 PM
                            • Adv10119
                              Need help please! schematic for LA-9982P rev 3.0 (A02)
                              by Adv10119
                              Please help, i need schematic diagram for Dell inspiron 3537 board LA-9982P rev 3.0 (A02). Specific for A02.
                              I have a one beep with no display problem. Did reprogrammed the bios but no luck. i tried to troubleshoot using rev 3.0 (A08) version schematic and boardview but there's components/rails in the schematic that is none in my actual board, this is why I'm having problem checking every power rail needed if ok. attached is the photo of my actual board.
                              I'm not sure if A02 and A08 is really different schematic version from each other, but I have to try....
                              01-31-2024, 01:18 AM
