Asus X50GL (F50GL) schematic
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    Good day folks. Does anyone happen to have a schematic for an Asus X50GL ? It's also called F5GL from what I've seen online. It's got an Nvidia graphics chip on it, for reference. I found the boardview, but no schematic. Thank you.
    Wattevah...
  • whatamidoing
    Boardview/schematic for an ASUS E3-PRO V5
    by whatamidoing
    i'm looking for a schematic/boardview for an ASUS E3-PRO V5 (NOT E3 PRO GAMING, has a different layout).
    I'm trying to find out where i can find SKTOCC# other than from the socket in order to ground it for a Coffee Lake mod. It must be somewhere near/around the SIO but I haven't found a datasheet for the NCT5539D this board has.
    I've also found the schematic for the similarly named E3 PRO GAMING V5 but it has a different SIO so it's not of much help. And I don't trust myself to hold still a multimeter probe on top of a LGA socket pin to find where it comes out the...
    01-18-2025, 09:17 AM
  • mysnoopy
    Asus FX516PC R6.0 schematic
    by mysnoopy
    Hello
    I need schematic for this model ASUS FX516PC R6.0
    Thanks.
    12-27-2024, 03:41 PM
  • Kirve
    I need schematic and diagram for Asus X556U Rev2.0 mb
    by Kirve
    "Hello friends. My Asus X556U laptop is not charging, not turning on, etc. I wanted to repair the motherboard, partly for learning purposes. One of the capacitors is giving a 24V output, and one of the MOSFET pins is also giving a 24V output, and honestly, this surprises me. I think I need to replace the capacitor, but I don’t know the capacitance value. I tried searching for a motherboard schematic but couldn’t find anything. Can you help me find the schematic or diagram?"
    12-18-2024, 11:09 AM
    Asus P4SD-LE-C Motherboard Schematic
    ASUS P4SD-LA (HP OEM) is a motherboard based on the Intel 865G...
    10-21-2024, 05:51 AM
  • razor_amd
    by razor_amd
    12-15-2020, 07:07 PM
