Re: BoardView for the MacBook Pro 15" A1707 820-00281
Really thanksss!!!
You Sir area a Steely Eyed Missile Man!Leave a comment:
thank you kindly!Leave a comment:
thanks a lotLeave a comment:
Deep appreciation to bluestone and chris-swe for the provided matters!!!Leave a comment:
Thank you!!!!Leave a comment:
any schematics for 820-00923 please?Leave a comment:
СпасибоLeave a comment:
somebody has schematics 820-00923 please?Leave a comment:
thanks bro !!!!!!Leave a comment:
Apple MacBook Pro 15 A1707 820-00281-A Boardview...
Channel: Schematics and Boardviews
10-26-2024, 04:10 AM -
Apple MacBook Pro 15" A1707 820-00281-A Schematic & BoardView...2 Photos
by leonemax81Hi guys I have a Macbook a1707 with motherboard 820-00281, without liquid damage that behaves strangely, with the battery connected the Macbook does not turn on and the USBC meter stops at 5v in loop, when I disconnect the battery the Macbook turns on and works fine, I have already tried to replace the battery twice without success, as soon as I connect the black cable of the battery the Macbook does not turn on, it stops at 5v and in loop.
by soflesHello there
I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
...11-21-2024, 05:25 AM -
by jesihi all techs
require some help on this 820-00281-A macbook motherboard came in dead and the pch bga U1100 (SR2NH), u5000 , Q7056 , U7000 and bios U6100 ,looks like these have been tampered with ..also the battery is swollen..
adapter usb c 20.5v 4.7a 96w , i persume it should power on mb without battery..
update:
when adapter plugged in , power switch which 3.3v on it , when power button pressed both fans come on after 6 secs for about 20secs approx then goes off , nothing on the display stays as blank.. the voltage at the usbc out start from...08-23-2025, 02:35 PM - Loading...
