hi, i try to fix a macbook 12 2016 (A1534, emc 2991, 820-00244-A) but i cant find pdf and board view if someone can help me i appreciate.
help pdf & brd A1534 820-00244-a
Re: help pdf & brd A1534 820-00244-a
The only i can find at the minute are all paid for cant seem too find a free one here is a link if you decide to buy one
https://***********/threads/a1534-82...hematic.25851/ -
here isAttached FilesPremium supporters get full download access and other benefits.
I need it all of these other one's aren't working for me. Thanks.Comment
.Attached FilesPremium supporters get full download access and other benefits.
OpenBoardView — https://github.com/OpenBoardView/OpenBoardViewComment
i'm need shematics pdf only 820-00244 ( A1534 2016-2017 EMC2991 )
Please send group thanks very muchComment
820-00244_08.brd is ok but to repair my logic board I need the bottom.brd ( the other side)
TksComment
Press space.OpenBoardView — https://github.com/OpenBoardView/OpenBoardViewComment
Tks , Flip board is into help/control option
About 820.00244.08 , one filter L4804 burn, one FPC broken on the logic board, and RD 095 was desolder
An other FPC was broken on the trackpadLast edited by conflagration; 10-16-2019, 11:10 AM.Comment
The owner tried to repair himself
Filter is burn
RD095 was dessolder
this Fpc connector was broken, waiting a new
A short burn one trace of the flex
The new fpc connector of the trackpad
A hot aera, I hope that the nand was not impacted
Repair is in progress and I'm waiting the FPC connector for the logic boardLast edited by conflagration; 10-16-2019, 12:15 PM.Comment
by _002_As I said. I cant for God's sake find anything related to this monitor. Heck the tcom board is a mystery itself. Half of normal testing points are renamed or missing. I cant even find some to test on. So I tried to find this model tcom. Across different search search engines. No luck. Can't find any schematics for this monitor or any boards. The backlight works perfectly. But when I see the front screen with input in shows some lines and doest show anything than lines. Most connections like vcon vdd vcc and vgh were normal in voltage of common monitor tcom boards voltages in found online. But...
Channel: BIOS Requests ONLY!
Hi, Im trying to find the area on the chip that contains all of my laptops information, but I havent found it. The laptop won't turn on anymore. I was updating the BIOS, and it was supposed to reboot itself, but it wouldnt turn back on. I ve tried every possible solution, every alternative on Lenovo forums, everywhere; I ve taken it to technicians, and no one has been able to fix it. I've already read the chip that contains the BIOS (Winbond 25Q128JSVQ) and searched for my laptops data, but they're nowhere to be found. I only find scribbles and lines of text indicating errors. Has anyone had a...
by corrizeHello, I search this connector (oxydated).
It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
Do you know how to find this connector please ? What is the exact name for find it ?
by sam_sam_samThis Dell computer is a pain in the a** because of it only has one memory slot this computer only had 4 megabytes of memory and slower than shit I found a 8 megabyte memory module and it is better but still slow as shit the maximum is 32 megabytes of RAM but I was not able to find one I found some that are 16 megabytes but they are 1600/128000 type and I am not sure if this computer will work with this type of memory or not
Dose anyone knows where I can find a 32 megabytes memory module for this computer because the battery still works fairly well still I would like to use it on my...-
- Loading...
