Dell E3540 LA-A491P Schematic and Boardview
  • Seshmaru
    • Apr 2017
    • 31
    • Estonia
    Could anyone help me out with a motherboard "ZAL00 LA-A491P REV: 1.0 (A00) 2013-06-24. Dell E3540
    need to replace a burnt component under "PQ803"
  • imranromi
    • Jan 2015
    • 1290
    • Pakistan
    Re: Dell E3540 Schematic
    Originally posted by seshmaru
    could anyone help me out with a motherboard "zal00 la-a491p rev: 1.0 (a00) 2013-06-24. Dell e3540
    need to replace a burnt component under "pq803"
    here try this.
    • Seshmaru
      • Apr 2017
      • 31
      • Estonia
      Originally posted by imranromi
      here try this.
      Thank you very much!
      found the blown component "MDU1516"
      • bohemian
        • Jun 2017
        • 9
        • morocco
        thanks
        • fyaagoub
          • 269
          • maroc
          Thank you very much
          • mafiaxxx
            • Sep 2020
            • 22
            awesomeeee!!! thank you!!!
            • adones
              • Nov 2015
              Could anyone help me i have burnt element pq701.Me question is if i put a wire from pin 1 to 3 will it start working and charge the battery
                • 22189
                https://www.badcaps.net/forum/showthread.php?t=88758
                Originally posted by piernov
                2. What not to do
                2.6. Never randomly bridge MOSFETs/fuse/components
                Bridging components can easily lead to the destruction of the board without any way to repair it.
                If it's a fuse, replace it with a matching fuse. If you don't, it will not be able to protect the board and if the source of the problem is still there, some other component will go up in flames.
                If it's a MOSFET, its purpose is to stop current from flowing through it when turned off, and allow current to flow through it when turned on. It's not necessarily always turned on, otherwise it wouldn't be there. If it's turned off when it shouldn't be, then there is an issue elsewhere in the circuit, bridging the MOSFET won't solve it.
                https://cdn.badcaps-static.com/pdfs/...de9e5c2e36.pdf
                  • 22189
                  Start a new thread in the main laptop forum if you want help -
                  https://www.badcaps.net/forum/forumdisplay.php?f=23
                  • truongvanduc
                    • Dec 2023
                    • 11
                    • Vietnam
                    boarview Dell Latitude 3540 - LA-A491P
                    • ps_sym
                      • May 2023
                      • ukraine
                      thanks
