Openflex Boardview: New boardview software (linux, windows and OSX)
  • inflex
    replied
    Re: Openflex Boardview: New boardview software (linux, windows and OSX)
    bump.
  • piernov
    replied
    Yep, we are using various C++11 features which requires at least GCC 4.9 (though it was mostly developed using the 5.x branch). Ubuntu 14.04 has GCC 4.8 and so does Linux Mint 17. You could add the ubuntu-toolchain-r/test PPA but I can't guarantee that it will work.
  • northpoint
    replied
    Originally posted by inflex
    Release 7.2 is now out.
    There's also now a YouTube video detailing some of the features of Openflex Boardview.
    YouTube Video : https://www.youtube.com/watch?v=6CrNRo1UP5g
    All the downloads : https://github.com/inflex/OpenBoardV...eases/tag/R7.2
    Getting compile error on Linux Mint 17.2 so, I guess I have to upgrade to 18 for the newer gcc. Ill do that tonight probably
    GCC version needs to be >= 4.9
    Im excited to try this out thank you.
  • inflex
    replied
    If you have bug reports or feature requests, please submit them via the github issues page.
    https://github.com/inflex/OpenBoardView/issues
  • highpulse
    replied
    donwloading
  • inflex
    replied
  • inflex
    replied
    Release 7.1 has been pushed out. It's only two minor changes but they do help with general consistency in terms of the user-interface.
    https://github.com/inflex/OpenBoardV...eases/tag/R7.1
  • inflex
    replied
    Already have made some minor tweaks from R7, made it so that the part-zoom ratio (usually 2.5x but it's a user-adjustable parameter) applies to all search result type zoom operations (netwebs, part/net searches, info panel selections).
  • inflex
    replied
    RELEASE 7 is now available.
    https://github.com/inflex/OpenBoardView/releases/tag/R7
    Win / linux (deb) / OSX binaries available, and of course the source.
    This is a fairly decent feature upgrade from R6.
    • Pin/net searching and highlighting has been cleaned up
    • Light and Dark themes improved, less 'busy'
    • Info-Panel now available on right-side of screen, adjustable width by mouse click-drag ( toggle with 'i' key)
    • Parts and pin-networks selectable on info-panel making for easier tracing of faults
    • Selected parts/pins are now auto-zoomed to facilitate in easier viewing
    • Selected pin, and others on network are now "oversized" when zoomed out to help locate them on the board
    • Improved FZ handling, including non-encrypted, and comma-decimal variants
    • FZ file extra data for parts now displayed
    • Small performance improvements
    • Search facility now offers substring, prefix, and whole-string matching
    • Search quicklists changed from buttons to actual lists
    RECOMMENDED: Remove the existing obv.conf file and let the new version generate a fresh one. If you have a FZ key already installed then copy that before removing the file.
  • inflex
    replied
    Getting close to my next release. Just waiting on a bit of information from piernov.
    Attached is the light and dark theme of the same screen. Colours are all adjustable, the themes are just 'base defaults'.
  • highpulse
    replied
    file ..... openboardview.exe !!!
    darwin for OSX ,
    debian for unix user ,
    .exe for windows users ..so donwload the .exe file
    thk piernov and inflex , you guys rock
  • inflex
    replied
    Originally posted by angel-boy
    so where is the downloads link for 7 x64 or 10
    The Win 7 x86/32-bit binary is the one for all the above. Since it's a small app and CPU demands/complexity isn't brutal there's no compelling reason to try multi builds for Windows.
  • angel-boy
    replied
  • remax
    replied
    Originally posted by highpulse
    hey guys , so wich key is to be added to the setup ? for i can open the asus 1000h boardview ?
    Your file was not encoded, I fix it with standart key.
    Is it a lot of not encoded FZ files on vinafix? Should I do support of them in my program?
  • piernov
    replied
    Published a release for highpulse: https://github.com/piernov/OpenBoard...leases/tag/N11
  • highpulse
    replied
  • remax
    replied
    The key to the last my file starts with
    0x546E3454 0xAE123456 0x8567845B 0x412345CD
    and continue as usual.
  • piernov
    replied
    Looks like I can't do anything with this one.
    Also the previous one uses a different compression level and uses ',' instead of '.' as the decimal delimiter. Support will be implemented soon in OBV.
  • remax
    replied
    You are realy cool if you did this. This is normal file, previous was corrupted
    Are ZLib signatures knowledge enough to decrypt the file?
  • inflex
    replied
    Originally posted by piernov
    We could try to implement an auto detection of this field but the best would be to get a working file or "fix it" (ie. add those last 4 bytes which here would be 7014 encoded as a 32 bit little endian int if I'm not mistaken).
    That's quite a talent you have for massaging out data from files.
  • inflex
    FlexBV FREE Edition - Modern Boardview software for Win, macOS and Linux
    by inflex
    Now available, FlexBV Free edition is a slimmed down product of the full licenced version.
    https://pldaniels.com/flexbv5 ( available on the downloads page or most of the way down on the main page )
    If you're looking for a modern alternative to existing boardview programs that's also cross platform then consider giving FlexBV Free a go.
    So what's missing?
    * Schematic/PDF coupling
    * Butterfly view
    * Donor board part searcher
    * Jobs
    * Annotations
    What's new/improved compared to others?
    * OBData...
    10-10-2023, 12:29 AM
  • ivtec
    install Linux on Windows 10 | Install Ubuntu on Windows 10 using Virtualbox ?
    by ivtec
    Has anybody installed Linux on Windows 10 using Virtualbox? and since my old PC will have support after oct 25 and won't update to 11 , i just want to use win 10 for Music notation program and use Progdvb iptv player .
    01-17-2025, 12:54 PM
  • Topcat
    The 2025 Operating System Thread
    by Topcat
    What OS are you running these days? I am down to 3 Windows workstations and one Windows Server on my LAN, everything that doesn't have a windows-specific need has been moved to Linux. Printing abilities with my large document centers are Linux's kryptonite; the reason for 2 of the Windows machines. The third machine still has Win7 on it, and isn't connected to the outside world. It has tons of software on it I use for diagnostics and updating various hardwares. My main rig is still Win10 Enterprise, so I had to vote Win10 in the poll...but I have overwhelmingly more linux machines than windows...
    Windows 11
    29.41%
    15
    Windows 10
    23.53%
    12
    Windows 8/8.1 or 7
    13.73%
    7
    Windows Vista (I'm a glutton)
    0%
    0
    Windows XP (I just can't let go!)
    3.92%
    2
    Windows 2000 / ME / 9x (Ok, this one is a funny, maybe!!)
    0%
    0
    Some flavor of Linux (brag on your distro in a post)
    25.49%
    13
    MacOS - OSX (Poor diluted souls!!)
    3.92%
    2
    Google Chrome/chromebox/chromebook
    0%
    0
    What's a PC? (The option for those with a phone stuck in their faces)
    0%
    0
    01-01-2025, 10:19 AM
  • obelix24
    Boardview software for Ipad OS
    by obelix24
    As in the title is there any usable boardview software for ipadOS ?
    Something like flexbv or boardview ?
    I was not able to find anything
    11-06-2024, 03:25 AM
  • japlytic
    DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
    by japlytic
    In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
    Tried (only with keyboard/mouse connected):
    • BIOS + database update
    • Using latest Windows 11 image built with official image creation tool
    • Previous setup version for Windows 11 installer
    • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
    • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
    • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
    06-19-2025, 04:59 PM
