Asus S301 Schematic or boardview
Re: Asus S301 Schematic or boardview
Here we Go: (j'en a fait une de plus par erreur)
Thanks for your Time Mon AmiLast edited by passete; 06-20-2016, 04:24 PM.Comment
le BQ -CIRCUIT DE CHARGE - it s no responsible to 3.3v and 5v .
il n'est pas responsable de la coupure de3.3v et le 5v mais il peut cause la coupure de la ligne de 19v .
je pense que dans votre cas -les voltages que vous avez donnez pour les pieds du bq montre la coupur de la ligne de 19v .....elle est claire et pas de vout pour la charge de battery .malgrè que Vin existe 19v.Comment
Ok, Voici les 2 Photos Refaites
Chip5 NCP CONCERNIN CPU
Chip7-chip9 J7= RT8207MGQW complete DDR2-DDR3 memory power supply controller 1.8v or 1.5v
chip 6 je ne peut rien dire car j'ai pas trouver son datasheet .
JC FL = RT8239BGQW Main Power Supply ControllerComment
give us the voltage of all pins of JC FL= RT8239B and J7 FL .
LE J7 on le connais qu'il cause le probleme de coupure de ligne de 19 volt et on le trouve damaged .
tu doit le tester .qu'il ne cause pas ici un court-circuit .
bonne chanceComment
I need first to measure JC and J7 ?Comment
Is the BQ735 the Boss sending the voltages for the 3 and 5 Volts lines ?
Dumb question, but i see what you mean.
Shame that others very know experts are reading and maybe moking !Last edited by passete; 06-21-2016, 04:03 PM.Comment
No, it's not a dumb question, the BQ735 will give 19V for all the other chips on the motherboard. If you don't have 19V on the power rail, nothing will function on the motherboard. So, you have 0V at the pin 4 of the BQ735, the motherboard is not powered by the adapter.Comment
No other component is getting Hot on the Mobo, so i assume that this BQ is not sending secondary 19V to the rest of the mobo ?
ThanksComment
by cobovoCan someone share the boardview for Asus Pro WS X570-ACE ...
08-01-2025, 04:16 PM -
by whatamidoingHello,
i'm looking for a schematic/boardview for an ASUS E3-PRO V5 (NOT E3 PRO GAMING, has a different layout).
I'm trying to find out where i can find SKTOCC# other than from the socket in order to ground it for a Coffee Lake mod. It must be somewhere near/around the SIO but I haven't found a datasheet for the NCT5539D this board has.
I've also found the schematic for the similarly named E3 PRO GAMING V5 but it has a different SIO so it's not of much help. And I don't trust myself to hold still a multimeter probe on top of a LGA socket pin to find where it comes out the...-
01-18-2025, 09:17 AM -
by DodoidHello!
I am looking for a schematic (if that's not out there, a boardview would suffice) for the ASUS PRIME H610I-PLUS D4, model 60MB1B20-MB0A01, rev 1.01. Are either of these available anywhere?-
07-25-2025, 05:11 AM -
by michalgI need a schematic or boardview for an ASUS Chromebook CB5500FE laptop. I want to program the Nuvoton NPCX797FC0BX microcontroller, and I don't know how the SWDIO, SWCLK, and nRESET signals are connected.
Channel: Schematic Requests ONLY!
07-20-2025, 04:22 PM -
by adamski1952Hi all.
Looking for asus prime b560m-a r1.02 boardview and schematic please.-
06-14-2025, 10:58 AM -
- Loading...
