Hi...need schematic Asus A550L....board code X550LC . REV 2.0..tq
Need schematic Asus A550L..
by whatamidoingHello,
i'm looking for a schematic/boardview for an ASUS E3-PRO V5 (NOT E3 PRO GAMING, has a different layout).
I'm trying to find out where i can find SKTOCC# other than from the socket in order to ground it for a Coffee Lake mod. It must be somewhere near/around the SIO but I haven't found a datasheet for the NCT5539D this board has.
I've also found the schematic for the similarly named E3 PRO GAMING V5 but it has a different SIO so it's not of much help. And I don't trust myself to hold still a multimeter probe on top of a LGA socket pin to find where it comes out the...-
01-18-2025, 09:17 AM -
by mysnoopyHello
I need schematic for this model ASUS FX516PC R6.0
Thanks.-
Channel: Schematic Requests ONLY!
12-27-2024, 03:41 PM -
by Kirve"Hello friends. My Asus X556U laptop is not charging, not turning on, etc. I wanted to repair the motherboard, partly for learning purposes. One of the capacitors is giving a 24V output, and one of the MOSFET pins is also giving a 24V output, and honestly, this surprises me. I think I need to replace the capacitor, but I don’t know the capacitance value. I tried searching for a motherboard schematic but couldn’t find anything. Can you help me find the schematic or diagram?"
Asus P4SD-LE-C Motherboard Schematic
ASUS P4SD-LA (HP OEM) is a motherboard based on the Intel 865G...-
Channel: Schematics and Boardviews
10-21-2024, 05:51 AM -
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
Channel: BIOS Requests ONLY!
- Loading...
