Compal QIWG6 LA-7988P Rev:1.0 schematic needed
    Pleace...schematic needed.
    P.S. just 7988!
    Re: Compal QIWG6 LA-7988P Rev:1.0 schematic needed
    hi, friend, la7981 same as la7988
    look at this:
    https://www.elvikom.pl/schemat-lenov...2.html?lang=ru
      hi, friend, thanks!
      What is the difference between the la7981 and the la7988?
        hi, on the page 2 you can see difference between the 2 platform, it's marked with green color, but you can use this diagram to troublshoot la7988p, connector and
        component are the same,
        you can post your problem, with your motherborad, i will help you
          La7988 MB I have but not display, VGA fx volt not avl, core volt also about 4v. Pls help with possible reason.
            big thanks,from russia)
              thankyou
                thanks
                  thanks.
