Da0u33mb6e0 rev:e
hp sleekbook 14- b17tu schematic needed
by knk2729dag3bembcd0 rev d Board view and Schematic needed for Non Graphic Conversion (DIS to UMA) as the Graphic chip is bad
Channel: Schematics and Boardviews
by re-atariHello all,
Does anybody have a schematic and/or boardview of the Gigabyte GA-H110-D3A mainboard available? It would really help me out big time...
This board was donated to me in a known non-working state. In its previous life it was used as a mining board, so I suspected bad caps and a relatively easy fix. My intention is to use the fixed board as a testbed for a Truenas or Unraid build. The previous owner told me that the mainboard started to act 'weirdly' after replacing the originally installed Celeron for an i5-6400, varying from starting up irregularly to not at...-
by camisaoHello,
I need your help finding the MSI GF63 12UDX (Board MS-16R81 VER_2.0) schematic.
I accidently inserted MSI USB a programmer that was connected to a board that has Neutral tied to GND, instead of connecting it to the USB-ISO that was on another port (Friday afternoon mistakes....).
Now it doesn't start. 😏
I've looked for burned parts but found none.
The 20V from the adapter are ok and the battery has 12V if I disconnect the battery plug.
I need the schematic to try to understand where there the problem may be or if it is repairable.
Thanks!...-
Channel: Schematic Requests ONLY!
by Gau_sahaSir ,
I need the schematic of h61m-s rev1.1 gigabyte motherboard.
Recently this board came to me for repair but could not find its schematic .
The problem of this board is no display but the board has a power on it .Processor is not heating .
For preliminary investigation i changed vga cable ,ram and processor but the same issue persist.
Whenever i switch on the motherboard monitor says NO SIGNAL .
The board is almost new .No sign of corrosion on the board seen .
- Loading...
