GL10FG schematics needed
+ More Options
Posts
  • salawayon
    • Nov 2012
    • 572
    • philippines
    It's toshiba P875... this unit got a shorted at VREG5 line..
    Thanks..
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: GL10FG schematics needed
    see here
    https://www.elvikom.pl/post95270.htm...=GL10FG#p95270
    Im Back... sort of...
    • kotnatan
      Banned
      • Apr 2014
      • 181
      • Ukraine
      INVENTEC GL10FG 6050A2492401 A02 REV X01 - Toshiba Satellite P875
      http://**************/load/noutbuki/platforma_inventec/inventec_gl10fg_6050a2492401_a02_rev_x01_toshiba_satellite_p875/310-1-0-29447
      • salawayon
        • Nov 2012
        • 572
        • philippines
        Could you upload the file here?
        Thanks..
        • Compute
          Master
          • Oct 2014
          • 97
          • Russia
          Давай модель платы,загружу сюда,у меня доступ и на ELVICOM и на Remont-aud есть
          • Compute
            Master
            • Oct 2014
            • 97
            • Russia
            6050axxxxx
            и что там на твоей плате дальше?
            • Compute
              Master
              • Oct 2014
              • 97
              • Russia
              В общем вот...
              • salawayon
                • Nov 2012
                • 572
                • philippines
                Thank you very much for the schematics... but i still can't locate the cause of short circuit at vreg5 or VRP5V0A_LDO. Disconnected PAD6120 and the short circuit was not on U6100 and C6120. It's on the opposite side that cause the problem. With pad6120 disconnected i can measure now the vrp3v3a but the vrp5v0a is not. Power switch voltage is ok. Base on the schematics i can't locate D3150 and U4441 on the motherboard. the motherboard i got had an intel base system only. No normal supply at bios chip.
                Any help on this matter?
                Thanks...
                • Compute
                  Master
                  • Oct 2014
                  • 97
                  • Russia
                  Now there is a short circuit on the vreg3/5 and L6100/L6150?
                  • salawayon
                    • Nov 2012
                    • 572
                    • philippines
                    Only at vreg5 line got a short. At L6100 and L6150 were normal. Is there any other components that were connected to this line? I can only locate and test D3155 and C6120. D3150, U4441 and D390 were all not installed on this board.
                    • Compute
                      Master
                      • Oct 2014
                      • 97
                      • Russia
                      Now PAD6120 disconnect?
                      And short-circuit on vreg5 not?
                      • salawayon
                        • Nov 2012
                        • 572
                        • philippines
                        If PAD6120 is being disconnected, vreg5 gives out 5vdc... right after PAD6120 is shorted.
                        • Compute
                          Master
                          • Oct 2014
                          • 97
                          • Russia
                          Applicable laboratory power supply , and find a short circuit
                          • Compute
                            Master
                            • Oct 2014
                            • 97
                            • Russia
                            Vreg5 little of connected
                            • salawayon
                              • Nov 2012
                              • 572
                              • philippines
                              Yes. Not much of circuit connected to vreg5 line as based on the schematics...
                              I'll try replacing tps51123 if i could get the needed 5vdc with a disconnected pad6120..
                              • Compute
                                Master
                                • Oct 2014
                                • 97
                                • Russia
                                No sense
                                Short in load vreg5, search done using laboratory power supply
                                • Touqeersiddiqui
                                  • Dec 2016
                                  • 19
                                  • Pakistan
                                  P875-s7200 gl10fg 6050a2492401-mb-a02
                                  • Fransleg
                                    • Apr 2017
                                    • 9
                                    • TOGO
                                    Bios
                                    • Pascal Komlassan
                                      • Jan 2017
                                      • 809
                                      • TOGO
                                      Originally posted by Fransleg
                                      Bios
                                      Very good ✅
                                        09-06-2024, 05:27 AM
                                        09-06-2024, 05:33 AM
                                        Toshiba Portege R30-C Notebook Specification for Upgrade or Repair
                                        This specification for the Toshiba Portege R30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the R30-C boardview and R30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
                                        09-06-2024, 05:30 AM
                                        Toshiba Satellite Z30t-A-10C Notebook Specification for Upgrade or Repair
                                        This specification for the Toshiba Satellite Z30t-A-10C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30t-A-10C boardview and Z30t-A-10C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                        Toshiba Satellite L50D-B-11V Notebook Specification for Upgrade or Repair
                                        This specification for the Toshiba Satellite L50D-B-11V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L50D-B-11V boardview and L50D-B-11V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
