GL10FG schematics needed
    It's toshiba P875... this unit got a shorted at VREG5 line..
    Thanks..
    Re: GL10FG schematics needed
    see here
    https://www.elvikom.pl/post95270.htm...=GL10FG#p95270
    Im Back... sort of...
      INVENTEC GL10FG 6050A2492401 A02 REV X01 - Toshiba Satellite P875
      http://**************/load/noutbuki/platforma_inventec/inventec_gl10fg_6050a2492401_a02_rev_x01_toshiba_satellite_p875/310-1-0-29447
        Could you upload the file here?
        Thanks..
          Давай модель платы,загружу сюда,у меня доступ и на ELVICOM и на Remont-aud есть
            6050axxxxx
            и что там на твоей плате дальше?
              В общем вот...
                Thank you very much for the schematics... but i still can't locate the cause of short circuit at vreg5 or VRP5V0A_LDO. Disconnected PAD6120 and the short circuit was not on U6100 and C6120. It's on the opposite side that cause the problem. With pad6120 disconnected i can measure now the vrp3v3a but the vrp5v0a is not. Power switch voltage is ok. Base on the schematics i can't locate D3150 and U4441 on the motherboard. the motherboard i got had an intel base system only. No normal supply at bios chip.
                Any help on this matter?
                Thanks...
                  Now there is a short circuit on the vreg3/5 and L6100/L6150?
                    Only at vreg5 line got a short. At L6100 and L6150 were normal. Is there any other components that were connected to this line? I can only locate and test D3155 and C6120. D3150, U4441 and D390 were all not installed on this board.
                      Now PAD6120 disconnect?
                      And short-circuit on vreg5 not?
                        If PAD6120 is being disconnected, vreg5 gives out 5vdc... right after PAD6120 is shorted.
                          Applicable laboratory power supply , and find a short circuit
                            Vreg5 little of connected
                              Yes. Not much of circuit connected to vreg5 line as based on the schematics...
                              I'll try replacing tps51123 if i could get the needed 5vdc with a disconnected pad6120..
                                No sense
                                Short in load vreg5, search done using laboratory power supply
                                  P875-s7200 gl10fg 6050a2492401-mb-a02
                                    Bios
                                      Originally posted by Fransleg View Post
                                      Bios
                                      Very good ✅
