hp pavilion 2000 schematic needed
    Motherboard model:
    NEWTON_CR&HR_HPC
    MV_MB_V1
    Re: CQ58-261SA schematics needed
    The problem with this unit it got no LCD BACKLIGHT. Flex ok and vled voltage is ok. Lcd lights ok...
      its led with on line of pins on the mobo connector?
        Yes. I've checked the cable and it's ok.
          its led or ccfl?
            Sorry i forgot.. It's LED.
              measure the first 3 pin and the last 4 pins.
              post the voltage here
                I've dove that already. At Lcd connector pins 2,3,4 got 3.3vdc and at pins 38,39,40 got 5vdc. Pin 36 (backlight ON) no voltage is present when the unit is ON. Pin36 line from lcd to mainboard connector is not broken.
                  I'm requesting for a schematics in order that i could see what parts should i check first.
                    take a photo.
                    no fuse around?
                      part no 688018-001 NEWTON_CR&HR_HPC MV_MB_V1
                        Re: hp pavilion 2000 schematic needed
                        please give me the schematic
                          check this.
                            this is not the same
                              cq58 2nd generation mother board circuit needed
                                here it is
                                  Cq58-281er schematic
                                  plz i need
                                  newton_cr&hr_hpc mv_mb_v1 e162264 schematic
                                    Re: Cq58-281er
                                    up
                                      Re: Cq58-281er
                                      i think not available but posting a schematic which is very close to your requirement. See if it helps
