Asus X70A schematic
  • inspirim
    • May 2013
    • 282
    • Italy
    Asus X70A schematic
    I need schemati for Asus
    model: X70A
    motherboard: K51AB REV 2.1
    thanks to all
  • Pascal Komlassan
    • Jan 2017
    • 805
    • TOGO
    Re: Asus X70A schematic
    Please I need the bios dump of this motherboard thanks
    • whatamidoing
      Boardview/schematic for an ASUS E3-PRO V5
      by whatamidoing
      i'm looking for a schematic/boardview for an ASUS E3-PRO V5 (NOT E3 PRO GAMING, has a different layout).
      I'm trying to find out where i can find SKTOCC# other than from the socket in order to ground it for a Coffee Lake mod. It must be somewhere near/around the SIO but I haven't found a datasheet for the NCT5539D this board has.
      I've also found the schematic for the similarly named E3 PRO GAMING V5 but it has a different SIO so it's not of much help. And I don't trust myself to hold still a multimeter probe on top of a LGA socket pin to find where it comes out the...
      01-18-2025, 09:17 AM
    • mysnoopy
      Asus FX516PC R6.0 schematic
      by mysnoopy
      Hello
      I need schematic for this model ASUS FX516PC R6.0
      Thanks.
      12-27-2024, 03:41 PM
    • Kirve
      I need schematic and diagram for Asus X556U Rev2.0 mb
      by Kirve
      "Hello friends. My Asus X556U laptop is not charging, not turning on, etc. I wanted to repair the motherboard, partly for learning purposes. One of the capacitors is giving a 24V output, and one of the MOSFET pins is also giving a 24V output, and honestly, this surprises me. I think I need to replace the capacitor, but I don’t know the capacitance value. I tried searching for a motherboard schematic but couldn’t find anything. Can you help me find the schematic or diagram?"
      12-18-2024, 11:09 AM
      Asus P4SD-LE-C Motherboard Schematic
      ASUS P4SD-LA (HP OEM) is a motherboard based on the Intel 865G...
      10-21-2024, 05:51 AM
    • razor_amd
      by razor_amd
      12-15-2020, 07:07 PM
