HP Pavilion dv6-7000 schematic
    I'm in need of a schematic for an HP Pavilion dv6-7114nr.
    It has the AMD a84500 series processor and the AMD A50m chip set. The HP mother board part number is 682180-001.
    Problem is it starts when ac is plugged in prior to using start button and then stops with a blinking caps lock and no video.
    Re: HP Pavilion dv6-7000 schematic
    How many blinks.
    Usually those blinks tells you whats wrong.
      Its a constant blink indicating a bad cpu. I tried a new cpu,and memory but no luck.
        There is no constant blinking.
        Try again. Count untill you see pause
          Reflow?
            This is also my problem before. Blink codes which points to cpu, most of the time is incorrect. Maybe its best described as processor, either central processor or graphics processor =) Whenever I received HP or Compaq units with that kind of blink I reflow gpu then it worked. But does not last. So I send it to owner working but for free because I know it will return again.
