sony vaio mbx 266 schematic needed
Re: sony vaio mbx 266 schematic needed
MBX-266 Sony schematic :
Attached FilesComment
Dear guys
i have same board with dead condition after installed OS so any solution kindly advice.Comment
if its a software issue. re install it again or install software OS that works recently.
Never stop LEARNING because life never stops TEACHING!Comment
Please help boardview for mbx 266 Z50CR S1202-2. Thanks in advanceComment
hi
As mentioned in prev posts , no schematic for this board but closely relatedLast edited by stingerchamp; 10-04-2020, 07:13 AM.Comment
SONY MBX-266 schematic (close related) attached
SONY MBX-266 schematic attachedComment
i personally checked ICs numbers match with Z50CR MBX-266 motherboard and their location is same .Comment
In sony vaio laptops mostly 5v/3.3v power supply controller RT8223M gets a hit.
https://datasheetspdf.com/datasheet/RT8223M.htmlComment
Need Sony Z50CR MB S1202-2 MBX-266 Schematic Please
Hi friend i need schematic for Sony Z50CR MB S1202-2 MBX-266 motherboard
in which am not getting backlight laptop is working fine
i check backlight fuse which is ok. am in confusion. any solution will be appreciated.
thank youComment
Pl find attached herewith the schematics for MBX 266 wistron Z50RComment
by Carlos#2003%Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
Sony Vaio PCG-NVR23 MBX-67 D9JK653JU4NE4 Laptop Schematic...
Channel: Schematics and Boardviews
11-06-2024, 05:50 AM -
Sony VAIO SVF153 Series DAHKDAMB6A0 Laptop Schematic
SVF153B1YM
SVF153B1GN
SVF1532APXB
SVF1532ACXW
SVF153A1YV
SVF15328SGB
VJF153F11X
SVF1532P1RB...-
11-06-2024, 04:38 AM -
Sony Vaio VPC-CW MBX-226 Laptop Schematic
M9A0...-
11-06-2024, 03:39 AM -
Sony Vaio VGN-P Series Laptop Schematic
Foxconn MBX-187...-
11-05-2024, 07:42 AM -
- Loading...
