The part used in the D2921 of the HP Elitebook Dragonfly G1 is broken and I want to replace it, but I don't know the manufacturer or model number and I'm in trouble. If anyone knows, please help me. I'm also looking for a circuit diagram.
HP Elitebook Dragonfly G1 schematic
Tags: None
What is the motherboard model number -
Please help. Does anyone know what this part is? I would be grateful if you could tell me the manufacturer and model number of this part and its function.1 PhotoComment
Oh! God!
It's the mcf12102g900-t
I'll order it right away
I hope this will fix it
Thank you so much1 PhotoComment
Please help me
I installed the above parts, but only 5V could be input to the USB-C1 port.
Does anyone have a circuit diagram or board view?
Model: HP Elite Dragonfuri gen1 HSN-132C
Prod ID 7WK08AV
SN# JPH117W7CBComment
by titimimohello Guys Titi here ,
hope you are ok,i am looking for help,any one with schematic of IB250CX schematic diagram( lenovo M710e)
mine has an ic above sata has removed and i can't guess the number or if it was a regulator
please if you know let me know the type of this chip
computer work except to recognize hdd or ssd disk ,normally i can't install windows even if disk shows up or run windows
thanks-
by Kirve"Hello friends. My Asus X556U laptop is not charging, not turning on, etc. I wanted to repair the motherboard, partly for learning purposes. One of the capacitors is giving a 24V output, and one of the MOSFET pins is also giving a 24V output, and honestly, this surprises me. I think I need to replace the capacitor, but I don’t know the capacitance value. I tried searching for a motherboard schematic but couldn’t find anything. Can you help me find the schematic or diagram?"
hello friends
can I get the hp elitebook 630 g 9 schematic-
10-15-2025, 12:49 PM -
by CraigRNeed a schematic for Hp Elitebook 830 G6 Motherboard 6050A3059101-MB-A01 found one for other motherboard but it's quite different than mine.
Channel: Schematics and Boardviews
09-09-2025, 11:02 AM -
by my2k2Kindly somebody share schematic diagram for Sharp 2T-C42EG1X (Board: QPWBNH1 96WJN1 )
Most of the smd resistors were burned
Thanks in advance...09-05-2025, 10:19 AM - Loading...
