Would anyone happen to have these for the iPad Air A2588? Thank you
Apple iPad Air A2588 (2022) board view and schematic
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by RWS93Brand: Apple
Model: A1990
Board number: 820-01041
Problem: I am not an Apple kind of guy to start with. But I am quite experienced with motherboard repairs in general. So the laptop is stuck with 5v 0.250A and does not negotiate 20v. Same symptom on all 4 USB C ports. When charger is plugged the amps start at around 0.060 then go trough: 0.100 - 0.180 - 0.230 - 0.244 and stay like this. Laptop responds to the power button: once I hold it long enough current goes down to 0.060A and then up to previous levels.
Board clean, no liquid damage, no corrosion.... -
by stefanbsThe laptop is Apple Macbook A1534 2017 with board 820-00687-А. The USB-C tester shows no voltage, there is 820-00244-А board available. I looked at both schematics, all connector signals seem to be the same. Did someone try to fit 820-00244-А board in A1534 2017?05-11-2025, 01:08 AM
by AKuchen87Hi there. I am currently trying to figure out if I am undergoing the sunk cost fallacy.
I’ve bought a very cheap MacBook Pro 14 A2442 off eBay. I did some checking and the symptoms were pointing towards a NAND failure.
After some consideration I got an original logic board from Apple as an replacement. However after installing I have no backlight.
I can see the Apple logo if I point a flashlight at it but the MacBook seems to be going to recovery mode.
anybody have an idea of what’s up here? Is the board dead on arrival or is my screen... - Loading...
