it5570 datasheet
  • Rahul Morya
    • 13
    • India
    it5570 datasheet
    anyone have acess to csdn?
    i need it5570 datasheet
    资源浏览查阅3333次。笔记本ECITE(联阳半导体)IT5570DATASHEETite的EC内核是803IT5570更多下载资源、学习资料请访问CSDN文库频道.
  • Rahul Morya
    • 13
    • India
    or ths
    资源浏览查阅861次。EC芯片IT5570datasheetIT5570更多下载资源、学习资料请访问CSDN文库频道.
    • Rahul Morya
      It5570 datasheet
      by Rahul Morya
      I need it5570-128pin Datasheet pls help.
      Kindly share pdf here
      03-03-2024, 12:25 AM
    • electomech-fixer
      First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
      by electomech-fixer
      I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
      I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
      09-15-2025, 01:42 AM
    • SoulFreeze
      Help finding datasheet for component marked G34662
      by SoulFreeze
      Hi, pulled this component, (I'm assuming it's a MosFET) from an LED COB video light. Im trying to find the datasheet so I can find an equivalent replacement but no luck. Any assistance with the datasheet would be appreciated.
      Failing that, a way to pick a suitable replacement component? If it's indeed a switching fet, I'm assuming I might need to measure the switching clock frequency and find a component that meets the power capacity?
      Its a pair of them driving a 130w Light. Takes in 19volts. I can borrow a scope to measure the switching freq....
      05-01-2025, 03:56 AM
    • Rainbow_Chameleon
      Searching Datasheet for AM113 IC by O2MICRO
      by Rainbow_Chameleon
      I got a dead HD6950 on Ebay to try my luck and repair it. There were a few broken off capacitors that I already replaced.
      Measuring the PCI-E lanes I got somewhat weird measurements, the gpu might or might not be dead.
      If I plug the GPU in, the core heats up and I also get VCore but on two inductors that measure 16 and 60 Ohms respectively (Memory and PEX I guess) there is no voltage.
      On one of the two buck-controllers (APW7165) the enable pin is pulled to GND and the other controller I just cannot find a datasheet for.
      So if anyone has a datasheet or at least...
      01-23-2025, 12:03 PM
      Surface Mount Fuses Fundamentals Datasheet
      TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
      TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
      10-07-2024, 06:07 AM
