Need clevo 6-71-nh5k0-d02a schematic or boardwiev
  • bilen
    • Aug 2014
    • 637
    • istanbul
    motherboard NH50HKMB-OC
  • AL._.EX
    • Dec 2022
    • 896
    • Belarus
    Service manual
    • styleangel
      • Nov 2014
      • 9
      • Viet Nam
      Originally posted by AL._.EX
      Service manual
      thank you so much
      • canali
        • Oct 2014
        • 195
        • turkey
        thank you so much
        • sunny198828
          • Nov 2022
          thank you so much
          • reformatt
            • Feb 2020
            • 1510
            This board also appeared in a Gigabyte G7 GD I recently fixed so the service manual was immensely helpful. The power brick is rated at 11.8 amps and the main power pin of the DC Jack had burnt a hole in the board. It required quite a bit of grinding out the layers as this was shorted to the ground plane. I coated the exposed layers with conformal coating and filled the hole with epoxy. I replaced the DC jack but I looped a piece of copper wire from some 20 amp mains power flex and ran it directly to EML1/EML2 input resistors. Also had to run a wire underneath as well but this was only for filtering caps.
            I don't really think this connector and board design is up to the job for nearly 12 amps. Here is the link for the connector:
            https://www.aliexpress.com/item/1005...16f26369RW4m03
            Click image for larger version  Name:	IMG_20251029_124012.jpg Views:	0 Size:	2.99 MB ID:	3756809 Click image for larger version  Name:	IMG_20251029_123935.jpg Views:	0 Size:	3.90 MB ID:	3756810
