Compaq Presario M2000 schematic diagram ?
  • tomodachi
    • Apr 2012
    • 610
    • Turkey
    I have a oldie-goodie Compaq Presario M2000 my friend gave me a few days ago, said there was a problem about screen he don't know
    I disassembled that oldie and baam! inverter cable socket on the LVDS cable was ripped off
    There are 5 cables colored yellow,brown, blue, black and green
    I can solder them directly on the inverter board but I don't know which cable goes where so I need a little help here guys, I googled it from the code on it and found a picture but it is not that high resolutioned and I can not see pins and colors,
    Below picture is biggest I can find, if you have that cable or at least a schematic of this model, your help will be very appreciated
  • Francisco.s
    • 686
    • Spain
    Re: Compaq Presario M2000 schematic diagram ?
    Can you see any reference number of the motherboard?
    • JJR
      • Mar 2013
      • 171
      Try this from the forums shared schematics, care of fddizon.
      Dave
      • Francisco.s
        • 686
        • Spain
        Dave
        Hi Dave, I have the same schematic as HP COMPAQ DV4000 - QUANTA CT3.pdf.
        That´s why is so useful, to indicate all the data from motherboard.
        Regards.
        • JJR
          • Mar 2013
          • 171
          It might be easier to replace the cable, found these on on ebay.co.uk
          http://www.ebay.co.uk/itm/COMPAQ-PRE...item5d39acef8c
          http://www.ebay.co.uk/itm/COMPAQ-PRE...item3374a5d664
          http://www.ebay.co.uk/itm/Compaq-Pre...item4ab7b526be
          http://www.ebay.co.uk/itm/Compaq-Pre...item589a746b48
          http://www.ebay.co.uk/itm/Compaq-Pre...item2322497fc2
          • tomodachi
            • Apr 2012
            • 610
            • Turkey
            I did not disassembled the machine, all I can say for now is model number;
            Compaq Presario M2207EA
            Dave
            Thanks for the schematic but mine is an AMD, is there an AMD version of that ?
            • JJR
              • Mar 2013
              • 171
              Hi Tomodachi
              I found that schematic here ftp://helpedia.com/pub/temp/uploads/ have a look see if you can find the right one.
              Dave
              • Francisco.s
                • 686
                • Spain
                I have googled it also, and one of the links refers to it as "Flexible Compaq V2000 Lcd Video Cable Ddct3blc101".
                Have a look to this:
                • tomodachi
                  • Apr 2012
                  • 610
                  • Turkey
                  thanks to all, I will see the schematics and let you know if there will be a happy ending or not
