Need ms-16k21 rev 2.1 schematic
  • bilen
    • Aug 2014
    • 637
    • istanbul
    help please
  • mcthr
    • Aug 2019
    • 25
    • Philippines
    Re: Need ms-16k21 rev 2.1 schematic
    • Sunil Patel
      • Mar 2016
      • India
      need MSI-16K21 boardview
      • PacoGT
        HP ENVY x360 gidget 8L 203038-1, boardview and schematic need
        by PacoGT
        hello firends
        i search the schematic or boardview
        I have this motherboard, but I can't find the schematic or the boardview.
        The problem is that on the chip marked where 3V should be, there are 5 volts, which indicates that the two are connected.
        So the computer doesn't turn on, and the 3V disappears after a few seconds.
        The original problem was that when I turned off the computer, the fan stayed on and saw that it was bad since it was directly in the 5V area.
        The new problem arose after removing the bad chip.
        3V and 5V remained together,...
        08-19-2025, 08:25 PM
      • hosain0489
        Request for Schematic and Boardview for HP Omen 16-xf0006AX (AMD Ryzen 7 7840H Version)
        by hosain0489
        I’m looking for the schematic and boardview files specifically for the AMD version of the HP Omen 16 laptop, model xf0006AX, equipped with the Ryzen 7 7840H CPU.
        Most of the files I’ve found are for Intel CPU versions, and I need the exact files for this AMD Ryzen 7 7840H model to assist with repair and troubleshooting.
        If anyone has access to these files or can kindly share the boardview and schematic for this particular AMD version, I would really appreciate your support.
        Thank you very much in advance!
        07-15-2025, 11:20 AM
      • re-atari
        Gigabyte GA-H110-D3A schematic/boardview needed
        by re-atari
        Hello all,
        Does anybody have a schematic and/or boardview of the Gigabyte GA-H110-D3A mainboard available? It would really help me out big time...
        This board was donated to me in a known non-working state. In its previous life it was used as a mining board, so I suspected bad caps and a relatively easy fix. My intention is to use the fixed board as a testbed for a Truenas or Unraid build. The previous owner told me that the mainboard started to act 'weirdly' after replacing the originally installed Celeron for an i5-6400, varying from starting up irregularly to not at...
        02-24-2025, 06:45 PM
      • jonyhdtv
        HP ProBook X360 11 G3 ee (winbook) schematic and boardview thanks
        by jonyhdtv
        Looking for schematic and boardview
        Model: HP ProBook X360 11 G3 EE
        Serial: SCG9114JG7
        Motherboard: L43774-601
        defect: touchscreen doesn't work (touch works on another computer)
        thanks to all​
        01-29-2025, 08:16 AM
      • jonyhdtv
        HP ProBook X360 11 G5 ee schematic and boardview thanks
        by jonyhdtv
        HP ProBook X360 11 G5 ee (winbook) schematic and boardview thanks
        Model: HP ProBook X360 11 G5 EE
        Serial: SCG0164QLH
        Motherboard: L83950-601
        defect: no POWER
        thanks to all​
        01-29-2025, 08:11 AM
