asus gl702vmk gtx 1060 firmware
  • jasko_jacker
    • Oct 2014
    • 1137
    • italy
    Hi
    I'm serching firmware for nvidia gtx 1060 6g (micron D9TCB)
    thanks
    • 20961
    Re: asus gl702vmk gtx 1060 firmware
    Originally posted by jasko_jacker
    Hi
    thanks
    Do you have a backup, it should be on a seperate chip to the bios.It will be around 64KB to 1MB i think.
    • cacla
      • Apr 2015
      • 442
      Hi
      thanks
      i think you need this
      • jasko_jacker
        • Oct 2014
        • 1137
        • italy
        Yes,
        the chip usually is a 25Q80EWSIG or 25Q40 , beware that there is two type of these chip one works at 1.8v and another at 2.7 volt
        I can't find a tool (there's Mobile Pascal TDP Tweaker) but it shows not the info
        as vram and a integrity check
        I The problem is too bright colors, with external monitor the problem is the same but The system works well even with very demanding games
        • jasko_jacker
          • Oct 2014
          • 1137
          • italy
          • jasko_jacker
            • Oct 2014
            • 1137
            • italy
            Have you a firmare for gl703vm gtx 1060 6g thanks
            • cacla
              • Apr 2015
              • 442
              give me sn from the unit
              • jasko_jacker
                • Oct 2014
                • 1137
                • italy
                Probably someone has changes the main bios or I report vm instead gm
                • cacla
                  • Apr 2015
                  • 442
                  Here mate
