i need lorex dv908 dump file please
LOREX dv908 dump
by CityminHi all,
S/N : 5RNK9FFT70...-
Channel: BIOS Requests ONLY!
by kenzo2I need dump file for nand A2159 512GB with 2 Nand chips >.I upgraded 128gb to 512gb..I use P13 there are only 4Chips...
I need dump file MACBOOK PRO A2159
TSB4232(256)
TSB4229(256)
Thanks​ -
by picouserPower off when the laptop is doing a BIOS update. The file seems corrupted, or the DMI data was written in the wrong place. Could someone help me with it? I uploaded the backup file from the BIOS chip and the generic file extracted from the HP website. Thanks!...
by m1ch43lzmHi everyone
There's also an extra OTP Secu.R...-
by bondminer009Good Evening,
Need help, is there any possible to get the bios file? Because received from my team without any dump file / original bios file
Thank You
Salam,
Three-
- Loading...
