Surface Laptop 3 1872 bios unlock
  • shiyab
    • Sep 2023
    • 1414
    • india
    #41
    Originally posted by janos6662000
    Hi
    Surface Laptop 3, model 1872, UEFI locked
    Serial no:
    012303595257​
    Please unlock
    hi try and feedback
    • janos6662000
      • Mar 2015
      • 27
      • Romania
      #42
      Originally posted by shiyab
      hi try and feedback
      Hello shiyab
      Thank you, i will try and get back with a feedback
      • janos6662000
        • Mar 2015
        • 27
        • Romania
        #43
        hi try and feedback
        Hello shiyab
        I tried, unfortunately the laptop does not boot anymore.
        Windows logo appears and disappears two times, but nothing after.
        Before, I could get to UEFI, but it was password protected, now I cannot get there anymore.
        • minhdigital
          • Nov 2022
          • 750
          • Vietnam
          #44
          Hello shiyab
          Try
          • janos6662000
            • Mar 2015
            • 27
            • Romania
            #45
            Originally posted by minhdigital
            Try
            Thank You, minhdigital
            Unfortunately we probably overheated the chip, because i cannot read/write it anymore.
            Luckily i have the good dump, i am waiting for a chip replacement.
            Until then i send another dump from another Surface, maybe i solve this one
            • janos6662000
              • Mar 2015
              • 27
              • Romania
              #46
              Hi
              Serial no:
              005912493657
              Please unlock​
              • shiyab
                • Sep 2023
                • 1414
                • india
                #47
                Hi
                Serial no:
                005912493657
                Please unlock​
                hi try and feedback
                • janos6662000
                  • Mar 2015
                  • 27
                  • Romania
                  #48
                  Hi shiyab
                  Tested and i working great, thank you very much.
                  I have another question.
                  One more Surface Laptop 3, serial 044335202257​
                  I read the dump, i thought that i figured out how to solve it and wrote back the dump modified by me.
                  Laptop is not starting, the Surface logo lights up one time and switches off.
                  I attach both locked and unlocked dumps, could you please check, if i did it right? Before i could enter the UEFI windows, but was asking for code.
                  Thank you one more time!
                  Best regards,
                  Janos
                  • shiyab
                    • Sep 2023
                    • 1414
                    • india
                    #49
                    Hi shiyab
                    Best regards,
                    Janos
                    hi try
                    • janos6662000
                      • Mar 2015
                      • 27
                      • Romania
                      #50
                      hi try
                      Hello shiyab
                      Thank you for yourhelp.
                      Unfortunately, the dump you sent is matching to the last byte the dump i tried to write back to the laptop.
                      Unfortunately the laptop isn't working with this content, only the logo flashes one time.
                      Not sure what is the next step.
                      I read the dump with multiple verifies, so the dump should be good.
                      • janos6662000
                        • Mar 2015
                        • 27
                        • Romania
                        #51
                        hi try
                        Hello shiyab
                        I would like to correct my previous post: Your dump is working great, there was a bad soldering issue, the laptop did not read the flash correctly. What i don't understand is, that we resoldered it a few times, with same result. I was getting suspicious, when i programmed back the original dump and we got the same result.
                        Then we checked again all the soldering and laptop started working, unlocked.
                        Thanks again!
                        • janos6662000
                          • Mar 2015
                          • 27
                          • Romania
                          #52
                          OK, one more, please
                          Just when i thought that i learned how to unlock, i got one Surface 3 Laptop, model 1872, serial number 021311600957
                          This one just flashes the logo once, then switches off.
                          It was never opened until now. I hope it is an UEFI issue, not a hardware issue.
                          I saw some cases when the poster solved it by an ME region cleaning...
                          Can anybody help me, what to try to start this one?
                          I attach original dump.
                          • onlymk
                            • Jan 2024
                            • 5
                            • Qatar
                            #53
                            I also want to build a firmware file for a Surface Laptop 3 1872 device with this model
                            SN:035922702157
                            • peste
                              • Dec 2016
                              • 12755
                              • ROMANIA
                              #54
                              SN:035922702157
                              post the contents of the bios chip even if it is corrupted..
                              • yasin4286
                                • Mar 2021
                                • 21
                                • my workshop
                                #55
                                Hello friends. The problem with this device is that it turns off after the Microsoft startup logo appears.
                                Thank you for your help.
                                Serial number: 037633604857
                                • peste
                                  peste commented
                                  Editing a comment
                                  post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                              • peste
                                • Dec 2016
                                • 12755
                                • ROMANIA
                                #56
                                post full name and model, motherboard model,etc.
                                • yasin4286
                                  • Mar 2021
                                  • 21
                                  • my workshop
                                  #57
                                  surface laptop 3 1872
                                  serial number 037633604857
                                  • yasin4286
                                    • Mar 2021
                                    • 21
                                    • my workshop
                                    #58
                                    any help
                                    • volinakis
                                      • Jan 2021
                                      • 2728
                                      • N/A
                                      #59
                                      try clean ME
                                      • yasin4286
                                        • Mar 2021
                                        • 21
                                        • my workshop
                                        #60
                                        Originally posted by volinakis
                                        try clean ME
                                        Thank you. But unfortunately it didn't work. The same problem still exists.
                                          Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                                          This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-06-2024, 08:47 AM
                                        • tekky5
                                          BIOS Unlock for Microsoft Surface 3 Laptop
                                          by tekky5
                                          Hello Friends! Trying to dump bios bin for Microsoft Surface 3 to recover UEFI password but running into error when running FPTW64 in CMD in Administrator mode:
                                          Code:
                                          fptw64.exe -bios -d dump.bin
                                          Intel (R) Flash Programming Tool Version: 13.0.37.1556
                                          Failed to Initialize driver for accessing PCI device.
                                          Error 51: Could Not access PCI device.
                                          Error 51: Could not access PCI device.
                                          Error 64: Failed to initialize SPI interface.
                                          FPT Operation Failed.
                                          More Details:
                                          1. I don't know the UEFI password, dumping bios to recover...
                                          11-11-2024, 10:36 AM
                                          Microsoft Surface Laptop Surface Laptop Go 2 Notebook Go 2 Specification for Upgrade or Repair
                                          This specification for the Microsoft Surface Laptop Surface Laptop Go 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop Go 2 boardview and Surface Laptop Go 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 06:11 AM
                                          Microsoft Surface Laptop Surface Laptop 4 Notebook 4 Specification for Upgrade or Repair
                                          This specification for the Microsoft Surface Laptop Surface Laptop 4 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 4 boardview and Surface Laptop 4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
