Dell Latitude 5430, LA-L591P Computrace setting unlock
    Re: Dell Latitude 5430, LA-L591P Computrace setting unlock
    Originally posted by Fixit2022 View Post
    here is the correctly bios
    try. 1st boot press F2, write Service Tag, disable Absolute, save, restart. 2nd boot press alt+F to exit manufacturing mode.
      I accidentally soldered the chip the wrong way around and now the notebook no longer starts no light nothing I just broke the chip or is the whole notebook defective.
        it happens again...put it back correctly and see what happens..maybe you'll be lucky...
          Unfortunately not. When I press the power button, the orange light lights up very briefly and nothing else happens. Is it possible to solder in another BIOS chip?
            Can I install this chip W25Q256JVEQ Flash IC or does it have to be exactly the W25Q256JVEN that is installed?
              yep, it's ok.
                hello, me too, i need help for:
                laptop / DELL LATITUDE 5430 /
                motherboard / HDB42 LA-L591P Rev:1.0(A00) /
                cpu / INTEL 12TH GEN /
                service tag / #9X9BRQ3-8FC8
                spi chip / WINBOND 32MB@WSON8
                thanks.
                  thanks.
                    Hello! I've got a locked Dell Latitude 5430 as well.
                    Admin password and Dell SafeBIOS enabled
                    Latitude 5430 / LA-L591P
                    Winbond 25Q256JVEN flash
                    Locked dump is attached. Thanks!
                      Here's your Unlocked Bios, hope it works fine.
                      all donations are welcome,
                        Hi, thanks for the file. With the new file flashed, I'm getting no power on the laptop and only an amber light when the button is held. I double checked the orientation of the SPI flash chip when resoldering it.
                        I only see 4 bytes of difference between the original and new files. Is that expected for this model?
                        Thanks!
                          Thanks!
                          check well the soldering bin that the hardware friend gave you is correct, check if you blew any resistor or capacitor near the bios... if you are not sure upload an image of the bios chip and its surrounding components
                            Got it. Turns out I didn't have the wson-8 SPI chip aligned quite right. I removed and resoldered the IC on, and now the laptop is functioning great!
                            Thanks for the help!
                              bios with admin lock , Please Unlock
                              Dell Latitude 5430
                              8FC8
                              Thank You
                                Dell Latitude 5430
                                8FC8
                                Thank You
                                Your Backup is not good, try to read it again correctly.
                                  Please try now. Thank You
                                    It's the same file.
                                    Which programmer do you use? Are you using a clip or de-soldering the Chip?
                                      de-soldering chip. try reading a few times and same result
                                      programmer is TL866 II Plus
                                        Attach a clear image for your Chip or what is written on it. Did you choose the same name of the Chip when you try to read it or auto detect?
                                          my chip is - 25Q256JVEN
                                          and my programmer have only that option - reading all same.
                                          see picture
