HP EliteBook X360 830 G8
    hp elitebook x360 830 G8 unlock
    Help
    unlock this dump ,got a pb with my unlocker.
      Re: hp elitebook x360 unlock
      Originally posted by lapfix View Post
      Help
      At 1st boot press F10 and RESET BIOS to factory defaults, save, restart and password will go on. After that enter in bios setup and in Main tab you have "set machine unique data" and write there what it's written on the label inside the cover. Or extract DMI from your bios dump:
      Feature Byte: 476J6S6b7B7H7M7R7W7maBaEapaqauawbVbhcAdpdqfAfPguhKhkj4jhk8mEn7nVngpq.eD (no spaces)
      Serial: 5CG3032BPM
      SKU: 3S8V8AV
      Build ID: 21WWOPDT601#SABF#DABF
      Board CT: PMGDD00WBHM0I3
      Name: HP EliteBook x360 830 G8
      Save and use BCU to exit MPM mode or restart laptop/desktop how many times counter shows.
      REMOVE CMOS BATTERY BEFORE WRITING BIOS!
        Re: Hp X360 830 G8
        clean bios HP ELITEBOOK X360 830 G8
        SERIAL Number :
        5CG24721WW
        BIOS dump attached
          Re: Hp X360 830 G8
          Originally posted by elaid02 View Post
          clean bios hp elitebook x360 830 g8
          serial number :
          5cg24721ww
          bios dump attached
          anyone here for help
          thanks in advance
            Re: Hp X360 830 G8
            thanks in advance
            " clean bios HP ELITEBOOK X360 830 G8 " . What's do you mean ?
            Become a Badcaps supporter
            Thanks to all supporters.
              Re: Hp X360 830 G8
              Originally posted by hoaca388 View Post
              " clean bios hp elitebook x360 830 g8 " . What's do you mean ?
              i mean remove password
                Re: Hp X360 830 G8
                  HP EliteBook x360 830 G8 bios
                  6050A3219701-MB-A01
                  SN:5CG1503L1F
                  hello please need dump for this laptop after i dump the bios in order to clear cmputrace but laptopn won't turn on also with the original bios
                    6050A3219701-MB-A01
                    SN:5CG1503L1F
                      Hello
                      I need some help
                      I have I 830 g8
                      factory whit no wifi enabled in the bios file only mobile sim
                      can somebody enable de wifi on this file
                      The serial is 5CG2135FMM
                      Thanks in advance
                        is there nobody that can help whit my problem
                          Originally posted by rickjansen01 View Post
                          Hello
                          I need some help
                          I have I 830 g8
                          Thanks in advance
                          Try
                            Hello Hoaca388
                            Thanks for the file and the replay
                            i wil check it and come back to you
                            Best regards chris
                              Hello Hoaca388
                              It is not working still no wifi
                              Any other solution
                              Regards chris
                                Hello Hoaca388
                                Any other solution
                                Regards chris
                                Sorry, There's also the "clear ME" operation, but I get an error and can't proceed. I hope someone else can do it for me
                                  Hello
                                  I need some help
                                  I have I 830 g8
                                  Thanks in advance
                                  try
                                    Hello Hoaca388
                                    thanks for your time
                                    Hello qayyum786
                                    the file works but the dmi info is not there anymore
                                    do you now the offset for this file to copy
                                    Best regards Chris
                                      MODEL : HP EliteBook 830 G8
                                      Serial NUMBER :5CG2135FMM
                                      SKU :- 19C72AV
                                      CTNumber:- 6LGWT10TZG78BC
                                      Build Id:- 21WWCVET601#SABE#DABE
                                      Feartube byte:- 3X476J6S6b7B7H7M7Q7W7m7saBaEaFapaqauawbUbhcAdUdpdqdzfAfPgSguhKjhk8mEn7nVng.Y2
                                        Hello qayyum786
                                        I know the info but i need to know the offset in de dump file from 0x to 0x
                                        Best regards chris
                                          TRY THIS IF NO LUCK THAN USE BCU WITH DMI INFO FROM POST #57
