hp 240 g6 caps blinking
  • hirens
    • May 2022
    • 179
    • uganda
    hp 250g6 blinking caps 5 times no display
    some one help me here thanks
  • hirens
    • May 2022
    • 179
    • uganda
    Re: hp 250 g6 caps blinking
    machine is 240 sorry not 250
    • cacla
      • Apr 2015
      • 442
      PLS give more info about the unit sn or motherboard number
      • hirens
        • May 2022
        • 179
        • uganda
        board number: DA0P1GMB6D1 rev D
        model: RTL8723DE
        • lapfix
          • Mar 2020
          • 2732
          • my workshop
          pls give more info about the unit sn or motherboard number
          sn :5cd9086p1k
          • hirens
            • May 2022
            • 179
            • uganda
            Originally posted by lapfix
            sn :5cd9086p1k
            yes exactly
            • cacla
              • Apr 2015
              • 442
              sn :5cd9086p1k
              I found some bios from HP site one is your bios but you need to add sn to bios
              Here it is
              • hardware1
                • Sep 2021
                • 2936
                • N/A
                Depending on your serial number from your dump file, the device model should be 240 G6 not 250.
                So try this file, and let me if it works.
                all donations are welcome,
                • hirens
                  • May 2022
                  • 179
                  • uganda
                  yeah i already mentioned that above
                  its 240 not 250
                  but let me try the file and give feed back
                  • hirens
                    • May 2022
                    • 179
                    • uganda
                    its 240 not 250
                    same results
                    • hirens
                      • May 2022
                      • 179
                      • uganda
                      Here it is
                      tried all these but none worked
                      • lapfix
                        • Mar 2020
                        • 2732
                        • my workshop
                        Re: hp 240 g6 caps blinking
                        Your bid is : BID084D6
                        • BNIBRAHIM
                          • Nigerian
                          Heat the graphics card.
                            by momaka
                            03-12-2025, 03:42 PM
                          • eryjus
                            by eryjus
                            05-10-2023, 11:21 AM
                          • Paxman_Swede
                            by Paxman_Swede
                            Hello!
                            01-14-2025, 09:51 AM
                          • captain150
                            by captain150
                            03-16-2025, 07:34 PM
                          • Foetuss
                            Gigabyte GA-6OXT :: caps question
                            by Foetuss
                            Good evening
                            I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                            Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                            But I was also suprised about the bigger boys, which are 330µF 25V.
                            Could it be they used 25V caps because they were cheaper / available at that time?...
                            02-11-2025, 12:22 PM
