Msi gs43vr 7re help me?
  • yucel-yucel
    • Dec 2017
    • 148
    • türkey
    The device triggers and draws an average of 1.5 ampere current.
    However, the image does not appear. When ram is installed and ram is removed, the amperage value is the same and there is no display. Tried the original bios on the site, the result is the same. I suspected the south chipset and changed the result. The result is the same. Unable to receive image from the device. Can you check if something is wrong with my original bios or give me an idea?
    MSI GS43VR 7RE
    MS-14A31 REV:2.0
    SR32Q CPU
    N17A-G1-A1
  • peste
    • 13924
    • ROMANIA
    Re: Msi gs43vr 7re help me?
    MSI GS43VR 7RE
    MS-14A31 REV:2.0
    SR32Q CPU
    N17A-G1-A1
    if you used the bios on the website and wrote it correctly, it should work... if it doesn't work, I think the laptop has another problem...try again..
    https://www.msi.com/Laptop/GS43VR-7R...om-Pro/support
    • yucel-yucel
      • Dec 2017
      • 148
      • türkey
      I detected 3 problems, Sr30w + Ram + Bios, and I ran the device with the bios on the site. Thanks.
      • macabook
        by macabook
        🧩 Initial Issue
        07-24-2025, 02:17 PM
      • cr4zychriss
        by cr4zychriss
        • Rebrand: PC Specialist
        11-14-2025, 04:04 PM
      • pirati
        by pirati
        10-27-2025, 04:20 PM
        by Vesko356
        08-11-2023, 03:27 AM
      • istvanszasz99
        Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
        by istvanszasz99
        Product ID: RZ09-0421
        Motherboard: CH580
        Bios File Size: 32,768 KB
        Dear Forum Readers!
        !!! MY RAZER BLADE...
        11-24-2025, 05:52 PM
