Lenovo Thinkpad E15 gen2 GE4B0/GE5B0 NM-D011
  • kalilinux25
    replied
    Originally posted by mauradin
    Hey it is the
    GE4B0/GE5B0
    NM-D01
    My biggest question right now, is do I have to solder wires onto the contacts by the 'JBIOS' area, and then get those onto my ch341a?
    Yes you can try I already confirm the connection they are connected to U2 line, but try if the Programmer can detect it , please remove the batery or any that can power the board to avaoid further damage
  • mauradin
    replied
    Originally posted by kalilinux25
    What is the Motherboard Model?
    Hey it is the
    GE4B0/GE5B0
    NM-D01
  • kalilinux25
    replied
    Hey all,
    My E15 Gen 2 stopped charging, and I attempted to troubleshoot. I installed the recommended bios, but it did not resolve the charging issue. I stupidly disabled the built-in-battery as per someone's instructions - however, this bricked my laptop because the AC power won't take, and now the battery is disabled. I attempted a CMOS reset, but I could not get the BIOS to reset to unselect the 'Disable Built-in Battery' option. So I am trying to reprogram my BIOS now.
  • struart
    replied
    please try
    On this BIOS laptop starts but theres no MAC address and Managment Version is blank in BIOS and dont detect NVME DISK.
  • peste
    replied
    I think so...follow the routes in the picture from post #2....
  • mauradin
    replied
    Hey all,
    On top of that I also wiped the wrong chip... Can someone get me an export of the data for the: 25Q80DVSIG chip?
    Additionally, for this laptop, since the BIOS is stored in 25R256JVEN, I don't see a way to desolder this chip, but I do see these contacts. Do I have to temporarily solder wires here to make this work? I'm unsure how to connect to this chip.
    My laptop:
    Serial: MJ-0G4908
    Type: 20TD-S00800
    Click image for larger version  Name:	Screenshot 2024-08-12 003810.png Views:	0 Size:	713.9 KB ID:	3327399
  • kalilinux25
    replied
    Originally posted by struart
    Hello
    I have Lenovo E15 Gen 2 NM-D011 Rev 1.0.
    Laptop starts, power led is on, nothing on screen and restart after 5-10 seconds.
    Laptop data:
    Motherboard NM-D011 Rev 1.0
    Serial number: PF-3PFE3P
    Type Number: 20TD-00GNPB
    P/N: SL11B03796
    Heres dump from Winbound 25R256JVEQ chip dumped via T48 programmer.
    Strange thing is that i cannot verify that chip with dump i made it always shows differencies no matter what programmer i use ch341/ez2013/t48. Chip in adapter no clip used.
    please try
  • struart
    replied
    Hello
    Laptop data:
    P/N: SL11B03796
  • hoaca388
    replied
    Originally posted by alihomee
    model is:lenovo E14
    serial is:PF-33A1QT
    tyep is:20TA-00DRMY
    when turns on it gives display with too loud beep and keep on restarting after cmos error...i attached orignal file
    E14 Gen 2 Laptop (ThinkPad) - Type 20TA
  • jomerfx28
    replied
    Lenovo ThinkPad e15 Gen2
    S/N: PF-33JCSV
    Board Label: GE4B0/G35B0 NM-D011 Rev 1.0
    Type #: 20TD-00B7US
    Fresh Bios Please. Thanks
  • alihomee
    replied
    model is:lenovo E14
    serial is:PF-33A1QT
    tyep is:20TA-00DRMY
  • Markus1741
    replied
    You are also welcome to watch this YouTube video, I just saw it today.
    In the Lenovo ThinkPad E14 E15 Gen 2 model, there seems to be a serious processing error in which the Mosfets initially detach from the circuit board due to heat.
    Maybe that will help.
    https://www.youtube.com/watch?v=FQM0cDefHi4
  • vladfxnet
    replied
    Originally posted by aminealae
    Re: Lenovo Thinkpad E15
    same problem but i hear whistle on 24256E
    Hello, have you solved the problem with the chip whistling? Perhaps we have the same problems with the board. My board starts blinking 3 times as usual and then gives continuous long light signals. The fan does not spin and the keyboard backlight does not turn on. If you solved this problem, tell me how?
  • HOSCARLY007
    replied
    Greetings with everyone.
    I have this problem.
    How can I disable Absolute Persistence?
    Lenovo E15 Gen 2 GE4B0/GE5B0 NM-D011 Rev. 1.0
    MTM: 20TBS7NR00
    SN.: PF3X****
    Por favor gracias
  • kalu
    replied
    Originally posted by bernalqz
    Thanks I have 2 chips: 25Q80DVSIG and 24256E
    Which is the BIOS chip?
    Click image for larger version  Name:	image.png Views:	16 Size:	831.6 KB ID:	3280158
    Click image for larger version  Name:	image.png Views:	14 Size:	900.0 KB ID:	3280159
    this is the 32MB EPROM
    Originally posted by Maxpower3
    how do you put 32mb into 1mb??
    with Winrar ?
    https://www.badcaps.net/forum/troubl...89#post1695089
  • redoxy
    replied
    Please help with my BIOS.
    Unsure what exactly I need but I am assuming a clean ME.
    Any expert here please suggest or point me in the right direction as to what might fix my issue.
    The laptop was working fine. I got a notification about a critical BIOS update to prevent a known charging issue.
    I updated BIOS using Lenovo update utility after the laptop won't boot.
    The power LED turns on for few seconds then off and repeats.
    When the power adapter is plugged in I can hear a high-frequency sound similar to what's described in post #9 of this thread.
    Machine type: 20TDS00B00
    Serial #: MJ0EKCYG
    Motherboard: GE4B0/GE5B0 NM-D011
    replied
    Originally posted by robert0934
    Yes, NM-D011, i have a feeling that my BIOS chip is not responding and readable but i also read somewhere that this chip is difficult for supporting programmer software due to extra security features. I am using the CH341a programmer.
    Thread merged.Post the chip part number
  • robert0934
    replied
    replied
    What model is the motherboard ? NM-D011
    You MUST:
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
  • robert0934
    replied
    Hi, i need a clean bios for :
    Lenovo thinkpad E15 gen 2 20TD model
    serial number PF-2NABTC
    20TD-0028MH​
    Thanks in advance !
