a1466 emc3178 bios lock
  • Francisamd1
    • Jul 2016
    • 38
    • Philippines
    help pls remove bios pass
    a1466
    2017
    820-00165-a
    emc 3178
  • DanielDacko
    • Mar 2015
    • 329
    • Macedonia
    Re: a1466 emc3178 bios lock
    try...
    I don't provide help for people using CH341A and a clip.
    • cr4zychriss
      by cr4zychriss
      • Rebrand: PC Specialist
      11-14-2025, 04:04 PM
    • sssssssssssssss
      Need BIOS for HP Pavilion 15-n058sr recovery - Caps Lock blinking twice
      by sssssssssssssss
      I'm dealing with a classic BIOS corruption issue on an HP Pavilion 15-n058sr and hoping someone here might have the original BIOS file or point me in the right direction.
      Symptoms:
      • Laptop powers on but no display at all (completely black screen)
      • Caps Lock blinks twice with a pause, then repeats continuously
      • F12 LED stays on permanently
      • No POST, no boot sequence, nothing on screen
      Based on HP diagnostic codes, the 2-blink Caps Lock pattern indicates BIOS corruption/failure.
      What I've tried:
      • Hardware reset (battery removal, power
      09-04-2025, 06:45 AM
    • haitham sharabati
      [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
      by haitham sharabati
      Hello engineers šŸ˜€,
      I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.šŸ˜
      šŸ”§ Device Info:
      - Model: HP 15-da2007ne
      - Product Number: 8XF55EA#ABV
      - Serial Number: CND0338P0D
      - CPU: Intel Celeron N4000
      - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
      šŸ’€ Problem:šŸ˜…
      - Device shows ā€œAdministrator Passwordā€...
      08-07-2025, 04:54 AM
    • ArtMov
      [HELP] Asus g732lv ami bios overclocking lock reseting after reboot
      by ArtMov
      Hi guys, i have a problem , my bios resets disabled overclocking lock setting to enable after reboot, please tell me which function can be responsible for restoring the stock config for this option, loading parameters from nvram and so on, like bios ,protection, from asus. My bios made me angry) Set default parameter to disable in amibcp 5 , doesn't help(
      1. I made overclocking lock disabled the default in amibcp
      2. I changed the varoffset to the wrong one, but it led to the programmer, it was very tedious and nervous, I really regretted it, my chip is on the back of the...
      03-31-2023, 01:30 PM
    • pirati
      by pirati
      10-27-2025, 04:20 PM
