HP 14s-dq****** DA0PAHMB8E0 REV:E bios
  • inv4der
    • Mar 2015
    • 26
    • Poland
    I need bios
    Main: DA0PAHMB8E0 REV:E
    CPU: i3-1115G4
    KBC: ITE 5570e-128
    Programming dump from the forum https://www.badcaps.net/forum/showthread.php?t=106437 does not detect M2 NVME and touchpad
  • peste
    • Dec 2016
    • 13728
    • ROMANIA
    Re: HP 14s-dq2009nw bios
    Originally posted by inv4der
    I need bios
    CPU: i3-1115G4
    KBC: ITE 5570e-128
    post the original bios of the laptop.
    • inv4der
      • Mar 2015
      • 26
      • Poland
      • Mazorca
        • Jan 2017
        • 463
        This is what I get from your bios bin:
        Serial Number : 5CD1080PN8
        Product Number : 320T9EA
        Description : HP Laptop
        ROHS Status : Not Assigned
        I have tried but can't get the bios update from HP USA website, perhaps you can download it yourself from your country and post it here? The BID number for yours is 087FD.
          • 22097
          When you can`t find it by the full model number look for the series instead
          14-dq2000
          https://support.hp.com/gb-en/drivers...q2000/36683209
          • Mazorca
            • Jan 2017
            • 463
            Hmmm, HP support did suggest that series but it was around 200 suggestions. From the Hex editor, I did see this: HP Laptop 14s-dq2xxx. Thanks for the tip, now back to work.
            Update, the BID numbers do not match, I got four bins from update, two 16's and two 8's, 086C8,0864B and 0864A,0864D. Given bin has 087FD.
            Further update; finally got BIOS from website, named 87FD.exe but will not open, error nag screen says HP Flash Utility (3.41 Build 11171) has stopped working. Advice?
            • blackmamba
              • Oct 2023
              • 3
              • italy
              hi guys, i have the flash bios problem, when i do the win + b + power on then it's "file not found" or black screen.
              The laptop is am hp 250 g7 - th mb is L49975601. Could you help me please?
              • Vesko356
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                Read the rules before posting:
                Become a Badcaps supporter
                Thanks to all supporters.
                • blackmamba
                  • Oct 2023
                  • 3
                  • italy
                  I'm sorry i'm in trouble, i was writing on the wrong thread.
                  • reeza_plus
                    • Aug 2015
                    • 59
                    • canada
                    can someone help fixing this file
                    mode: 0PAH da0pahmb8e0 rev:e
                    14-dq2033ca
                    • Vesko356
                      Vesko356 commented
                      Editing a comment
                      You MUST:
                      Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
                      Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
                  • macabook
                    by macabook
                    🧩 Initial Issue
                    07-24-2025, 02:17 PM
                  • cr4zychriss
                    by cr4zychriss
                    • Rebrand: PC Specialist
                    Today, 04:04 PM
                  • pirati
                    by pirati
                    10-27-2025, 04:20 PM
                  • Vesko356
                    by Vesko356
                    08-11-2023, 03:27 AM
                  • jbonavita
                    by jbonavita
                    Some issues
                    Things I tried
                    04-29-2025, 09:38 PM
