Asus GL503V, DABKLMB28A0 REV:A
  • warsztat
    • Feb 2017
    • 190
    • Polska
    Asus GL503V, DABKLMB28A0 REV: A, no screen, after switching on, the oscilloscope measurement on RAM shows some waveform.
    I am attaching a bios dump, I am asking for another functional one.
    https://www.badcaps.net/forum/attach...1&d=1654771472
    Regards
  • hoaca388
    Badcaps
    • Jan 2022
    • 11817
    Re: Asus GL503V, DABKLMB28A0 REV:A
    Asus-GL503VD
    • warsztat
      • Feb 2017
      • 190
      • Polska
      unfortunately no success
      still the same problem
      • warsztat
        • Feb 2017
        • 190
        • Polska
        Originally posted by hoaca388
        Asus-GL503VD
        Bios ok, I was wrong. After the flash chip of the bios, I noticed that caps lock is working, LCD is ok, but not the backlight.
        Thank You.
        • hoaca388
          Badcaps
          • Jan 2022
          • 11817
          Thank You.
          Test again with an external monitor via HDMI, if there is a picture then hardware failure.
            • 21048
            Thank You.
            Post a picture of the square white QR code near the battery connector
            • Jasonexe
              • Apr 2023
              • 69
              ASUS GL503VD Bricked ?
              I'm hoping that there's someone that will be able to help me. I have a ASUS GL503VD, when i go to the bios it asks me for a password. I don't remember it because i didn't use the laptop for a while. I wanted to remove the password by reflashing the bios. I desoldered the bios IC and I erased/reprogrammed the bios IC with the CHA341a programmer. The bios file type is CAP, i used UEFITools to get a rom file of it. The bios IC is MX25L6473F. I soldered the IC back on to the motherboard and tried to turn on the laptop and the only thing that goes on is the keyboard backlight, it would turn on and off every couple seconds. I did this method before to other laptops and never had a problem until now.. am i missing something?
              • peste
                • 12887
                • ROMANIA
                Re: ASUS GL503VD Bricked ?
                you probably didn't write the correct version of the bios on the chip for the respective motherboard, or you didn't extract the bios correctly from the "CAP" file.. post the original bios of the laptop, I hope you made a copy!! or clear pictures with a square white with a QR code..
                • Marc97
                  • Jan 2016
                  • 189
                  • Phillipines
                  i have also asus ROG GL503V BOARD NUM DABKLMB28A0 REV A
                  Mine has a problem of cant power off board,, if you shutdown the unit power led still on, keyboard back light on, fan spinning,, so i remove battery to off,, then i on again windows all normal,, if you shutdown problem cant power off board even waiting many minutes
                  i attached bios file
                  • peste
                    • 12887
                    • ROMANIA
                    read post #6
                    • Marc97
                      • Jan 2016
                      • 189
                      • Phillipines
                      read post #6
                      thank you we will update sooner the pict thank you very much
                      • Marc97
                        • Jan 2016
                        • 189
                        • Phillipines
                        read post #6
                        thank you sir,, here is the pict of bar code
                        • peste
                          • 12887
                          • ROMANIA
                          also post the serial number..S/N...
                          • Marc97
                            • Jan 2016
                            • 189
                            • Phillipines
                            Unit serial H9N0CX19K888381...
                            MODEL GL503V
                            • peste
                              • 12887
                              • ROMANIA
                              Originally posted by marc97
                              unit serial h9n0cx19k888381...
                              Model gl503v
                              try...
                              • Marc97
                                • Jan 2016
                                • 189
                                • Phillipines
                                try...
                                thank you so much,, it works,, ill try to observe and format the unit..
                                more power godbless
                                • zaido
                                  • Sep 2017
                                  • 20
                                  • philippines
                                  pls help build my bios no display
                                  DABKLMB28A0 REV A
                                  SN: H9N0CX29T49839G
                                  • peste
                                    • 12887
                                    • ROMANIA
                                    DABKLMB28A0 REV A
                                    SN: H9N0CX29T49839G
                                    try post#15..
                                    • zaido
                                      • Sep 2017
                                      • 20
                                      • philippines
                                      i tried already but no display
                                      • mrtlty363
                                        • Feb 2019
                                        • 5
                                        • türkiye
                                        Asus-GL503VD
                                        WORKİNG THANXXXXX
