need help to unlock IBM THINKBAD T42 bios password
  • bembeno
    • Feb 2016
    • 310
    • egypt
    im searching for the file to programing the atmel chip to unlock the ibm t42 laptop
  • hoaca388
    Badcaps
    • Jan 2022
    • 12281
    Re: need help to unlock IBM THINKBAD T42 bios password
    Try this way :
    Reset the jumper that holds the password
    Open the computer and locate on the motherboard the BIOS password jumper. The jumper is usually jumper 1 and often labeled as PSWD, PWD, CLRPWD, CLEAR, JCMOS1, CLR, CLEAR CMOS, PASSWD, or PASSWORD. Normally you would have 3 pins and to reset the password you just need to put the jumper on the 2 and 3 pins leaving pin 1 empty. After you move the jumper, turn the computer on to clear the password, then once password removed turn it off and put the jumper back to its original position.
    • bembeno
      • Feb 2016
      • 310
      • egypt
      there is no jumper its laptop not pc
        • 21692
        https://www.badcaps.net/forum/showthread.php?t=59243
        24RF08 or similar
        It could be any of these 93C46, C4C61, 24C01, 24C03, 24RF08, 24RF08 equivalent P24S08, PS08, L08, 08 as well as LSI EEPROM PC8394T and 8356908
        • zenius
          by zenius
          12-08-2024, 06:13 AM
        • Nopslide
          by Nopslide
          04-01-2024, 04:27 PM
        • outsider
          Panasonic FZ-G1 MK5 - BIOS password returning
          by outsider
          Hello
          I removed the BIOS password thanks to the help of one of the friends of this forum.
          https://www.badcaps.net/forum/troubl...61#post3637661
          The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
          06-17-2025, 12:51 AM
        • BlackVisor
          How to Decode BIOS password for RedmiBook Pro15 2022 6800H
          by BlackVisor
          RedmiBook Pro 1542022 6800H
          SKU: TM2113-39463
          Model Number: RMA2204-AB
          CMIIT ID: 2022AP1835
          SN: 39463/22WD01355
          BIOS version: RMARB5B0P1010 20230628
          1. I bought this laptop from flea market, and the seller said that he had never set a password, however here is a password required when pressing F2 to enter BIOS.
          2. And after entering incorrrect password 3 times, there is no any useful information like "recovery code"
          3. I used universal bios backup tool, and dumped 8MB bin file, but hex code after "SystemSupervisorPw" is...
          01-14-2024, 06:35 AM
        • RMDUiFT
          Should I buy a Lenovo Thinkpad E495 with bios password?
          by RMDUiFT
          Good day. I apologize if I posted this in the wrong topic. I saw somebody selling a Thinkpad E495 with a Ryzen 3500U CPU near me. In the pictures the laptop is running windows 10. I contacted the seller and asked a few questions about upgradability and if it has a bios password on it. He confirmed it has a bios password. I searched through the forum, I found a guide regarding removing the bios password using the autopatcher, I also found a thread with the e495 where people requested help with unlocking the bios password.
          I have a few questions:
          • If I would buy this laptop and have
          08-25-2024, 09:00 AM
