Dell Latitude 3410 - BIOS Repair Request - Corrupt Flash
  • UEFIUnited
    • May 2022
    • 5
    Hey,
    I'm after some help please with a Dell Latitude 3410 laptop I've been looking into.
    In order to get my bearings with BIOS/UEFI chip flashing, I first used my CH341A USB flasher to extract the data from both the XMC QH64AHIG and XMC QH128AHIG chips (the larger chip I believe contains the ME data). I desoldered the smaller QH64AHIG chip due to access restrictions as my clip would not fit onto of the chip.
    Data from both chips was read via Colibri, as the version of AsProgrammer I normally use (v2.1.0.13) wouldn't recognise either of the chips. I erased the data from both chips and then wrote back to the chips the .bin images I had created.
    The purpose of this was to see if I can successfully read, erase and rewrite a BIOS/UEFI image upon a Dell laptop.
    Unfortunately the laptop no longer boots once the CMOS battery, battery unit and RAM and replaced. When the mains power pack is reconnected, if the power button is pressed the power indicator turns on for a split second (it will remain on if the power button is held in). No other action from the laptop can be seen.
    I have a funny feeling its to do with the way the Colibri application is reading the chip's data but I may be wrong. I've uploaded the contents of both chips .bin images.
    If possible, can someone please inspect the .bin images to see if there's any defects which explain my issues? Also, if there's an alternative more reliable application to use for reading/writing/erasing in combination with the CH341A flasher.
    May eventual goal was to place the laptop into factory mode.
    Cheers
  • hoaca388
    Badcaps
    • Jan 2022
    • 12333
    Re: Dell Latitude 3410 - BIOS Repair Request - Corrupt Flash
    Latitude 3410
    • CapThatBrass
      • Oct 2021
      • 46
      Thanks for the reply and file Hoaca388.
      Have you got any advise in terms of the application to use in order to flash the chips with?
      Cheers
      • CapThatBrass
        • Oct 2021
        • 46
        I had the same issue some time ago but nobody replied.
          • 21936
          Cheers
          Try NeoProgrammer ,Colibri ,Flashrom with the CH341A.
          • CapThatBrass
            • Oct 2021
            • 46
            Thanks SMDFlea, I'll give NeoProgrammer a try
            • UEFIUnited
              • May 2022
              • 5
              Hey,
              Thanks guys for your responses. I've downloaded the .bin files as well as NeoProgrammer, all seems to have flashed without any issues.
              However, when I attempt to boot the laptop there's no response from the unit, with the charging cable plugged in the laptop displays a charging LED but that periodically turns off and back on again, almost as though it begins to charge then simply stops but tries again.
              Is there something incorrect with the BIOS images? I made sure both chips were erased (as well as blank checked) before writing to them and then verifying.
              Any help would be greatly appreciated.
              Cheers
              • hoaca388
                Badcaps
                • Jan 2022
                • 12333
                Originally posted by UEFIUnited
                Hey,
                Cheers
                Maybe ME region is the problem.
                • UEFIUnited
                  • May 2022
                  • 5
                  Hey Hoaca388, thanks for getting back to me.
                  Does the zipped BIN images you've uploaded in your last message have the correct ME region settings?
                  Cheers
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12333
                    Cheers
                    #8 does not interfere with ME region, like your original bios.
                    • ram1969
                      • Oct 2022
                      • sudan
                      hello everyone i have dell latitude 3410 core I3 i was doing rest for bios password but accidentally the chip was earse i have the copy of the bin file was inside the chip i tray to rewrite it with ch431a but it says disagremnt butween the chip and bin file it syas the chip larger the bine file the chip is XMC QH128AHIC I wounder if anyone here can help me to fix this problem.
                        • 21936
                        Use the software at post #5
                        • aldopc
                          • Jul 2017
                          • 477
                          • Chilito
                          Hello friends, can you help me to repair this file is hanging on the dell logo
                          • aldopc
                            • Jul 2017
                            • 477
                            • Chilito
                            Solved
                            • wahabmahmood48
                              • Jan 2023
                              • 13
                              • Pakistan
                              DELL 3410 ST:JH6N563 3AMBER 5 WHITE LIGHT BLIKING AND STUCK ON DELL LOGO PLZ FIX THE BIOSE
                              • wahabmahmood48
                                • Jan 2023
                                • 13
                                • Pakistan
                                hello sir plz help me
                                • rex98
                                  • Feb 2023
                                  • 1293
                                  • Mandaue CEBU, Philippines
                                  use my post number 161 flash both.
                                  https://www.badcaps.net/forum/troubl...92#post3252592
                                    DELL Latitude 3410 Notebook 3000 Specification for Upgrade or Repair
                                    This specification for the DELL Latitude 3410 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3410 boardview and 3410 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 3410...
                                    09-06-2024, 08:40 PM
